Motorola Moto Z2 Play Screen Replacement
Views: 24K
View statistics:
Past 24 Hours:
3
Past 7 Days:
34
Past 30 Days:
130
All Time:
23,643
Comments: 10
1 comment on steps, 9 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace the screen on your Motorola Moto Z3 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you're replacing the display anyway, then you don't have to worry—but if you intend to re-use the display, take serious care when heating and inserting tools to separate the display from the rest of the device.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Motorola Moto Z2 Play Screen Replacement, Screen Removal: step 1, image 1 of 1
      • Power off your phone before you complete any replacement steps.
      Ask FixBot
    2. Motorola Moto Z2 Play Screen Replacement: step 2, image 1 of 1
      • Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
      • If screen is cracked put strong adhesive tape across the screen in order to avoid breaking the screen further and receiving cuts.
      • If you don’t have access to a heat gun, a hair dryer can be used.
      Ask FixBot
    3. Motorola Moto Z2 Play Screen Replacement: step 3, image 1 of 1
      • Place suction cup in the middle of the screen and press down.
      Ask FixBot
    4. Motorola Moto Z2 Play Screen Replacement: step 4, image 1 of 3 Motorola Moto Z2 Play Screen Replacement: step 4, image 2 of 3 Motorola Moto Z2 Play Screen Replacement: step 4, image 3 of 3
      • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
      • Work your way around the screen with the plastic opening tool.
      • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
      • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
      Ask FixBot
    5. Motorola Moto Z2 Play Screen Replacement: step 5, image 1 of 3 Motorola Moto Z2 Play Screen Replacement: step 5, image 2 of 3 Motorola Moto Z2 Play Screen Replacement: step 5, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Use a suction cup to lift up screen from left to right.
      • If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly.
      • Failure to lift screen from left to right can cause damage to interior wires of your phone.
      Ask FixBot
    6. Motorola Moto Z2 Play Screen Replacement: step 6, image 1 of 3 Motorola Moto Z2 Play Screen Replacement: step 6, image 2 of 3 Motorola Moto Z2 Play Screen Replacement: step 6, image 3 of 3
      • Identify ribbon connector at the top right of the phone.
      • Pry the black locking bar up gently with a plastic opening tool.
      • Remove the ribbon wires by pulling them out of the connector with a tweezer.
      • The locking bar is the small black bar located on the digitizer’s ZIF connector.
      • Be sure to push the locking bar back down using a spudger after you put the ribbon wire back in since the lock does not lock automatically.
      Ask FixBot
    7. Motorola Moto Z2 Play Screen Replacement: step 7, image 1 of 3 Motorola Moto Z2 Play Screen Replacement: step 7, image 2 of 3 Motorola Moto Z2 Play Screen Replacement: step 7, image 3 of 3
      Buy
      • Identify the ribbon cable, located at the bottom right of the phone.
      • If present, remove kapton (orange) tape covering the cable connector.
      • Flip up the small locking flap on the ZIF connector and use tweezers to slide the cable straight out of its socket.
      • Excessive force is not needed.
      Ask FixBot
    8. Motorola Moto Z2 Play Screen Replacement: step 8, image 1 of 1
      • Lift the screen from the phone to completely detach.
      • If screen doesn't detach, go back to step 7 and 8 to make sure the bar is unlocked and ribbon connector is fully detached.
      • During reassembly, you may need to apply or replace the display adhesive on your display assembly. Use our display adhesive application guide to apply the adhesive and reseal your device.
      Ask FixBot
    1. Motorola Moto Z2 Play Screen Replacement, Fingerprint Sensor Removal: step 9, image 1 of 1
      • Apply an iOpener to the bottom edge of the display assembly for about a minute to loosen the adhesive beneath the fingerprint sensor.
      • A heat gun may also be used, but take care to not heat one area of the display assembly for too long, as this could damage the display.
      Ask FixBot
    2. Motorola Moto Z2 Play Screen Replacement: step 10, image 1 of 2 Motorola Moto Z2 Play Screen Replacement: step 10, image 2 of 2
      • Carefully pry off the fingerprint sensor by lifting it with the edge of an opening pick.
      Ask FixBot
    3. Motorola Moto Z2 Play Screen Replacement: step 11, image 1 of 1
      Buy
      • Remove the fingerprint sensor with a pair of tweezers.
      • During reassembly, transfer the fingerprint sensor onto the new replacement display and press it into place.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer any remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Answers community for troubleshooting help.
27 other people completed this guide.
mitch miller
2,085 Reputation
8 Guides authored
Cal Poly, Team S19-G5, Livingston Winter 2018 Member of Cal Poly, Team S19-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G5
4 Members
96 Guides authored
9 Guide Comments
This is a guide for disassembly only. There are a few further steps required to replace front,,,
Jon Burgess - Reply Share
The locking bar came completly off the phone. Is there a way to attach it back? I sure hope so or I’m screwed. Thanks
stang82gt - Reply Share
nice man! i did this as well, i used paper card out of a deck of cards. works well BUT! look at where the cables run from your home botton/ fingerprint button and from you screen. i think i dammaged my home button by forcing my card pas the cable ripping it out of the motherboard.
chris - Reply Share
Anyone have a link to a suitable stand alone fingerprint/home button adhesive? Maybe the adhesive pack sold here has it included but not sure. Ordered from another site and it wasn’t included. Can somebody confirm or provide another compatible adhesive/seal substitute?
eks1934 - Reply Share
anyone else having a problem with the replacement screen not fitting? it seems like there is a bulge in the middle preventing the adhesive from keeping the screen attached to the frame on either side (top and bottom seals fine)
MANAGER - Reply Share
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 130
All Time: 23,643
