Motorola Moto X4 Battery Replacement
    1. Motorola Moto X4 Battery Replacement, Heat the screen: step 1, image 1 of 2 Motorola Moto X4 Battery Replacement, Heat the screen: step 1, image 2 of 2
      • Before you begin, turn off your phone.
      • Heat an iOpener and apply it to the left edge of the phone for two minutes.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      • As you wait, take note of the the following areas:
      • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
      • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
      Ask FixBot
    2. Motorola Moto X4 Battery Replacement, Create a gap: step 2, image 1 of 3 Motorola Moto X4 Battery Replacement, Create a gap: step 2, image 2 of 3 Motorola Moto X4 Battery Replacement, Create a gap: step 2, image 3 of 3
      • Apply a suction cup to the screen, as close to the heated edge as possible.
      • Pull on the suction cup with strong, steady force to create a gap in the seam.
      • Insert the point of an opening pick into the gap.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
      Ask FixBot
    3. Motorola Moto X4 Battery Replacement, Slice the screen adhesive: step 3, image 1 of 3 Motorola Moto X4 Battery Replacement, Slice the screen adhesive: step 3, image 2 of 3 Motorola Moto X4 Battery Replacement, Slice the screen adhesive: step 3, image 3 of 3
      • Slide the opening pick along the edge to slice through the adhesive.
      • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Motorola Moto X4 Battery Replacement: step 4, image 1 of 3 Motorola Moto X4 Battery Replacement: step 4, image 2 of 3 Motorola Moto X4 Battery Replacement: step 4, image 3 of 3
      • Heat the top edge of the phone with an iOpener.
      • Carefully slice around the corner and through the top edge to separate the adhesive.
      Ask FixBot
    5. Motorola Moto X4 Battery Replacement: step 5, image 1 of 3 Motorola Moto X4 Battery Replacement: step 5, image 2 of 3 Motorola Moto X4 Battery Replacement: step 5, image 3 of 3
      • Heat the screen's right edge with an iOpener.
      • Be careful not to slice too deeply near the cables to avoid damaging them.
      • Use an opening pick to slice along the right edge to separate the adhesive.
      Ask FixBot
    6. Motorola Moto X4 Battery Replacement: step 6, image 1 of 2 Motorola Moto X4 Battery Replacement: step 6, image 2 of 2
      • Repeat the previous steps to heat and slice the bottom edge of the phone.
      Ask FixBot
    7. Motorola Moto X4 Battery Replacement: step 7, image 1 of 2 Motorola Moto X4 Battery Replacement: step 7, image 2 of 2
      • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
      • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
      Ask FixBot
    8. Motorola Moto X4 Battery Replacement: step 8, image 1 of 1
      • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
      • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      Ask FixBot
    9. Motorola Moto X4 Battery Replacement, Detach the fingerprint sensor cable: step 9, image 1 of 2 Motorola Moto X4 Battery Replacement, Detach the fingerprint sensor cable: step 9, image 2 of 2
      • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
      • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
      Ask FixBot
    10. Motorola Moto X4 Battery Replacement, Disconnect the fingerprint sensor: step 10, image 1 of 3 Motorola Moto X4 Battery Replacement, Disconnect the fingerprint sensor: step 10, image 2 of 3 Motorola Moto X4 Battery Replacement, Disconnect the fingerprint sensor: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
      • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
      Ask FixBot
    11. Motorola Moto X4 Battery Replacement, Disconnect the display cable: step 11, image 1 of 3 Motorola Moto X4 Battery Replacement, Disconnect the display cable: step 11, image 2 of 3 Motorola Moto X4 Battery Replacement, Disconnect the display cable: step 11, image 3 of 3
      • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
      • Use tweezers to carefully slide the display cable out of the ZIF socket.
      Ask FixBot
    12. Motorola Moto X4 Battery Replacement, Remove the screen: step 12, image 1 of 2 Motorola Moto X4 Battery Replacement, Remove the screen: step 12, image 2 of 2
      • Remove the screen.
      • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
      Ask FixBot
    1. Motorola Moto X4 Battery Replacement, Unscrew the midframe: step 13, image 1 of 2 Motorola Moto X4 Battery Replacement, Unscrew the midframe: step 13, image 2 of 2
      • Remove the following twenty screws securing the midframe:
      • Eleven silver 2.7 mm-long T3 screws
      • Nine black 3.6 mm-long T4 screws
      • The midframe is still held in place by clips.
      Ask FixBot
    2. Motorola Moto X4 Battery Replacement, Loosen the midframe: step 14, image 1 of 3 Motorola Moto X4 Battery Replacement, Loosen the midframe: step 14, image 2 of 3 Motorola Moto X4 Battery Replacement, Loosen the midframe: step 14, image 3 of 3
      • The next few steps show how to loosen the midframe clips.
      • Insert the flat end of a spudger under the right edge of the metal midframe and pry up to loosen the midframe.
      • Insert an opening pick in the edge to hold the midframe in place.
      Ask FixBot
    3. Motorola Moto X4 Battery Replacement: step 15, image 1 of 2 Motorola Moto X4 Battery Replacement: step 15, image 2 of 2
      • Insert the flat end of a spudger under the lower right edge of the midframe and pry up to release the midframe clip.
      Ask FixBot
    4. Motorola Moto X4 Battery Replacement: step 16, image 1 of 3 Motorola Moto X4 Battery Replacement: step 16, image 2 of 3 Motorola Moto X4 Battery Replacement: step 16, image 3 of 3
      • Grasp the lower edge of the midframe and pull the edge slightly to the right, to clear the metal midframe clip.
      Ask FixBot
    5. Motorola Moto X4 Battery Replacement: step 17, image 1 of 2 Motorola Moto X4 Battery Replacement: step 17, image 2 of 2
      • Insert the point of an opening pick under the top left corner of the midframe and twist slightly to release the top clip.
      Ask FixBot
    6. Motorola Moto X4 Battery Replacement, Remove the midframe: step 18, image 1 of 3 Motorola Moto X4 Battery Replacement, Remove the midframe: step 18, image 2 of 3 Motorola Moto X4 Battery Replacement, Remove the midframe: step 18, image 3 of 3
      • Remove the midframe.
      • To reinstall the midframe:
      • Align the the midframe's top edge to the phone and press it into position.
      • Shift the bottom edge slightly to the left, to maneuver the left metal midframe clip underneath the phone edge.
      • Press the midframe's bottom edge into position.
      Ask FixBot
    1. Motorola Moto X4 Battery Replacement, Disconnect the battery: step 19, image 1 of 2 Motorola Moto X4 Battery Replacement, Disconnect the battery: step 19, image 2 of 2
      • Insert the point of a spudger underneath the top edge of the battery connector.
      • Be careful not to dislodge the small surface-mounted components surrounding the socket.
      • Gently pry up the connector to disconnect the battery.
      Ask FixBot
    2. Motorola Moto X4 Battery Replacement: step 20, image 1 of 3 Motorola Moto X4 Battery Replacement: step 20, image 2 of 3 Motorola Moto X4 Battery Replacement: step 20, image 3 of 3
      • To re-connect the battery, align the connector on top of the socket, and press it down with your finger or a spudger.
      Ask FixBot
    1. Motorola Moto X4 Battery Replacement, Battery: step 21, image 1 of 1
      • The battery is held in place by two thin strips of adhesive on the underside of the battery.
      Ask FixBot
    2. Motorola Moto X4 Battery Replacement, Loosen the battery: step 22, image 1 of 3 Motorola Moto X4 Battery Replacement, Loosen the battery: step 22, image 2 of 3 Motorola Moto X4 Battery Replacement, Loosen the battery: step 22, image 3 of 3
      • Slide the tip of an opening pick under the lower edge of the battery
      • Slowly push the pick in halfway to loosen the adhesive.
      • Insert another opening pick alongside the first pick, and slowly press it in until the adhesive releases the battery.
      • If you are having trouble, you can apply some high-concentration (over 90%) isopropyl alcohol along the battery edges to help soften the adhesive.
      Ask FixBot
    3. Motorola Moto X4 Battery Replacement, Remove the battery: step 23, image 1 of 1
      Tesa 61395 Tape
      $8.95
      Buy
      Ask FixBot
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
20 other people completed this guide.
Arthur Shi
346,849 Reputation
923 Guides authored
5 Guide Comments
I want to change my motorola x4 mobile's battery. Where should I go to get the better service (means the original battery and the best service centre)?
Himadri Shekhar Nandi - Reply Share
My battery keeps overheating and drains quickly. I did everything to close background apps to no avail. Does that mean I need new battery?
Traude Schwerzler - Reply Share
Hi Traude,
It may be that your battery is damaged and is has a minor internal short. This can cause the battery to drain and overheat. Replacing the battery would be the first thing I’d try. However, it may also be a motherboard problem.
Arthur Shi - Reply Share
Replaced my moto x4 battery last night as a father daughter project. It was brilliant fun, thank you.
Will West - Reply Share
je vous remercie infiniment
louvens st-laurent - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 109
All Time: 30,649
