Motorola Moto Q Front Casing Replacement
    1. Motorola Moto Q Front Casing Replacement, Back Casing: step 1, image 1 of 1
      • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
      • Be careful not to poke yourself when handling the push pin because it is very sharp.
      Ask FixBot
    2. Motorola Moto Q Front Casing Replacement: step 2, image 1 of 1
      • Use the T6 screwdriver to remove the four screws holding the casing together.
      • Note: they are in the same place where you removed the four rubber coverings
      Ask FixBot
    3. Motorola Moto Q Front Casing Replacement: step 3, image 1 of 2 Motorola Moto Q Front Casing Replacement: step 3, image 2 of 2
      • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
      • Note: the phone should be face up and the plastic opening tool should be face downwards
      • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
      • Repeat the 3 steps above for the top, bottom, and opposite side.
      Ask FixBot
    4. Motorola Moto Q Front Casing Replacement: step 4, image 1 of 2 Motorola Moto Q Front Casing Replacement: step 4, image 2 of 2
      • Gently lift and remove the back casing.
      Ask FixBot
    1. Motorola Moto Q Front Casing Replacement, Camera: step 5, image 1 of 2 Motorola Moto Q Front Casing Replacement, Camera: step 5, image 2 of 2
      • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
      • Gently rotate/wiggle the cover until you can pull it off the phone.
      Ask FixBot
    2. Motorola Moto Q Front Casing Replacement: step 6, image 1 of 2 Motorola Moto Q Front Casing Replacement: step 6, image 2 of 2
      • Using your fingers, remove the plastic piece that holds the camera in place.
      Ask FixBot
    3. Motorola Moto Q Front Casing Replacement: step 7, image 1 of 2 Motorola Moto Q Front Casing Replacement: step 7, image 2 of 2
      • Carefully pry up the upper circuit board with the spudger.
      • The second picture shows what your phone should look like when the upper circuit board is removed.
      Ask FixBot
    4. Motorola Moto Q Front Casing Replacement: step 8, image 1 of 2 Motorola Moto Q Front Casing Replacement: step 8, image 2 of 2
      • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
      Ask FixBot
    1. Motorola Moto Q Front Casing Replacement, LCD Display: step 9, image 1 of 2 Motorola Moto Q Front Casing Replacement, LCD Display: step 9, image 2 of 2
      • Remove the infra red plastic covering,the button on the left side of the phone, and the earphone cover lid by pulling straight up on them with your fingers.
      • Wedge the plastic opening tool in between the logic board and the small orange band and gently pry upwards.
      • Note: the orange band is connected to the logic board by a small connector.
      Ask FixBot
    2. Motorola Moto Q Front Casing Replacement: step 10, image 1 of 3 Motorola Moto Q Front Casing Replacement: step 10, image 2 of 3 Motorola Moto Q Front Casing Replacement: step 10, image 3 of 3
      • Wedge the spudger in between the logic board and the front casing and gently lift while pulling away from the orange ribbon.
      • Note: it is easier to remove the logic board by prying upwards near the top of left corner phone.
      Ask FixBot
    3. Motorola Moto Q Front Casing Replacement: step 11, image 1 of 3 Motorola Moto Q Front Casing Replacement: step 11, image 2 of 3 Motorola Moto Q Front Casing Replacement: step 11, image 3 of 3
      • Wedge the plastic opening tool between the LCD screen and the metal casing holding it in and lift gently.
      • Note: the LCD screen is also held in place by a silver tape. Simply pull the screen from one side to other to remove the screen completely.
      Ask FixBot
    1. Motorola Moto Q Front Casing Replacement, Keyboard: step 12, image 1 of 3 Motorola Moto Q Front Casing Replacement, Keyboard: step 12, image 2 of 3 Motorola Moto Q Front Casing Replacement, Keyboard: step 12, image 3 of 3
      • The keyboard is held in place with a little bit of glue.
      • Simply lift the keyboard buttons with your hands pulling from one side to the other.
      Ask FixBot
    1. Motorola Moto Q Front Casing Replacement, Front Casing: step 13, image 1 of 1
      • Remove the navigation buttons by pushing them with your finger(s) until they come loose.
      • Now simply peel the buttons off.
      • The buttons are held in place by glue. it may require a little extra pull to take off the buttons.
      Ask FixBot
Luis Herrera
91 Reputation
4 Guides authored
Cal Poly, Team 16-33, Maness Winter 2010 Member of Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 42
All Time: 17,695
