Motorola Moto Q Camera Replacement
    1. Motorola Moto Q Camera Replacement, Back Casing: step 1, image 1 of 1
      • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
      • Be careful not to poke yourself when handling the push pin because it is very sharp.
      Ask FixBot
    2. Motorola Moto Q Camera Replacement: step 2, image 1 of 1
      • Use the T6 screwdriver to remove the four screws holding the casing together.
      • Note: they are in the same place where you removed the four rubber coverings
      Ask FixBot
    3. Motorola Moto Q Camera Replacement: step 3, image 1 of 2 Motorola Moto Q Camera Replacement: step 3, image 2 of 2
      • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
      • Note: the phone should be face up and the plastic opening tool should be face downwards
      • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
      • Repeat the 3 steps above for the top, bottom, and opposite side.
      Ask FixBot
    4. Motorola Moto Q Camera Replacement: step 4, image 1 of 2 Motorola Moto Q Camera Replacement: step 4, image 2 of 2
      • Gently lift and remove the back casing.
      Ask FixBot
    1. Motorola Moto Q Camera Replacement, Camera: step 5, image 1 of 2 Motorola Moto Q Camera Replacement, Camera: step 5, image 2 of 2
      • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
      • Gently rotate/wiggle the cover until you can pull it off the phone.
      Ask FixBot
    2. Motorola Moto Q Camera Replacement: step 6, image 1 of 2 Motorola Moto Q Camera Replacement: step 6, image 2 of 2
      • Using your fingers, remove the plastic piece that holds the camera in place.
      Ask FixBot
    3. Motorola Moto Q Camera Replacement: step 7, image 1 of 2 Motorola Moto Q Camera Replacement: step 7, image 2 of 2
      • Carefully pry up the upper circuit board with the spudger.
      • The second picture shows what your phone should look like when the upper circuit board is removed.
      Ask FixBot
    4. Motorola Moto Q Camera Replacement: step 8, image 1 of 2 Motorola Moto Q Camera Replacement: step 8, image 2 of 2
      • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
      Ask FixBot
Dave Uth
41 Reputation
1 Guide authored
Cal Poly, Team 16-33, Maness Winter 2010 Member of Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,293
