Motorola Moto Q Back Casing Replacement
    1. Motorola Moto Q Back Casing Replacement, Back Casing: step 1, image 1 of 1
      • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
      • Be careful not to poke yourself when handling the push pin because it is very sharp.
      Ask FixBot
    2. Motorola Moto Q Back Casing Replacement: step 2, image 1 of 1
      • Use the T6 screwdriver to remove the four screws holding the casing together.
      • Note: they are in the same place where you removed the four rubber coverings
      Ask FixBot
    3. Motorola Moto Q Back Casing Replacement: step 3, image 1 of 2 Motorola Moto Q Back Casing Replacement: step 3, image 2 of 2
      • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
      • Note: the phone should be face up and the plastic opening tool should be face downwards
      • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
      • Repeat the 3 steps above for the top, bottom, and opposite side.
      Ask FixBot
    4. Motorola Moto Q Back Casing Replacement: step 4, image 1 of 2 Motorola Moto Q Back Casing Replacement: step 4, image 2 of 2
      • Gently lift and remove the back casing.
      Ask FixBot
Luis Herrera
91 Reputation
4 Guides authored
Cal Poly, Team 16-33, Maness Winter 2010 Member of Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 5,622
