Motorola Moto G7 Plus Screen Replacement
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
141
All Time:
12,986
Comments: 20
7 comments on steps, 13 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you want to perform advanced repairs on the Motorola Moto G7 Plus (model XT1965), you will likely need to remove the screen first. This guide will show you how to quickly and easily do so. If additionally you want to replace the screen, follow the steps of this guide in reverse using a new screen and adhesive as necessary.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
If you are removing a shattered screen, applying force may cause glass shards to pop off. Be gentle and, if necessary, use eye protection.
There are some required tools that are listed below. Ensure the phone is turned off before beginning.
Tools
    1. Motorola Moto G7 Plus Screen Replacement, Remove the Screen: step 1, image 1 of 2 Motorola Moto G7 Plus Screen Replacement, Remove the Screen: step 1, image 2 of 2
      • Insert an opening tool pick under the screen, starting at the top of the phone.
      • Slide the pick around the entire perimeter of the display to break the adhesive.
      • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
      • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
      • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
      Ask FixBot
    2. Motorola Moto G7 Plus Screen Replacement, Remove the Display Cable Cover: step 2, image 1 of 2 Motorola Moto G7 Plus Screen Replacement, Remove the Display Cable Cover: step 2, image 2 of 2
      • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
      • Gently remove the metal piece that covers the base of the display cable.
      Ask FixBot
    3. Motorola Moto G7 Plus Screen Replacement: step 3, image 1 of 2 Motorola Moto G7 Plus Screen Replacement: step 3, image 2 of 2
      • Use the pointed end of the spudger to lift the metal casing where circled.
      Ask FixBot
    4. Motorola Moto G7 Plus Screen Replacement, Separate the Display From the Phone: step 4, image 1 of 2 Motorola Moto G7 Plus Screen Replacement, Separate the Display From the Phone: step 4, image 2 of 2
      • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
      Ask FixBot
10 other people completed this guide.
Xander Wallace
257 Reputation
1 Guide authored
Cal Poly, Team S22-G5, Regan Winter 2020 Member of Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
5 Members
60 Guides authored
13 Guide Comments
Althrough a simple fix, one should be weary if the glass is shattered. I just did this, and there were a few spliters left on the adhesive, and of course sticking to it. So if you want to replace your screen due to broken glass, make sure to wear protection and remove the splinters carefully, otherwise you may be tempted to press on the new display to strongly, because you want to stick it to the whole brim.
isoein typ - Reply Share
I completed this fix, and it wasn’t too bad. Just watch out when gluing back the screen not to put glue over the microphone hole at the bottom. This would be the phone microphone mouthpiece, you can see a small notch on the bottom of the screen, beside the “motorola” “m” on the front . I put glue there without knowning and the microphone is now very muted.
Richard Gauvreau - Reply Share
Thank you for the heads up about the. microphone hole…
Great article! Keep it up, this really helps out us broke fellows.
DIY OR DIE!!!
Michael V - Reply Share
What can I do if I broke the cable connected to the back
Gary Dixon - Reply Share
i recently brought a mot g 7 screen replacement and followed the steps and the screen still doesn’t turn on
Javier Ortega - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 141
All Time: 12,986
