Motorola Moto G7 Plus Fingerprint Sensor Replacement
  1. Motorola Moto G7 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: step 1, image 1 of 2 Motorola Moto G7 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: step 1, image 2 of 2
    • Insert an opening pick under the screen, starting at the top of the phone.
    • Work the pick along the edges of the phone while placing them in the corners.
    • After placing the picks along the edge of the screen, refer to step 2.
    • Unlike the front of the phone, it is fine to use the picks on the left side of the phone because there are no cables that can be damaged.
    • While not necessary, applying a heat gun will weaken the adhesive, making this step significantly easier and quicker.
  2. Motorola Moto G7 Plus Fingerprint Sensor Replacement: step 2, image 1 of 2 Motorola Moto G7 Plus Fingerprint Sensor Replacement: step 2, image 2 of 2
    • Loosen the adhesive by cutting along the sides of the phone with the Jimmy Knife and prop open the back.
    • It is possible to use the opening pick to remove adhesive from the edges of the back case, however, it is much more difficult.
  3. Motorola Moto G7 Plus Fingerprint Sensor Replacement: step 3, image 1 of 2 Motorola Moto G7 Plus Fingerprint Sensor Replacement: step 3, image 2 of 2
    • The fingerprint sensor is now visible and can be replaced.
    • Remove the sensor cable with the metallic cover on top.
    • No tools or screws are necessary to remove the cable as it should easily come right off.
Arun Ganesh
121 Reputation
1 Guide authored
Cal Poly, Team S22-G5, Regan Winter 2020 Member of Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
5 Members
19 Guides authored
3 Guide Comments
Hello, the connector of the fingerprint scanner isn’t actually detachable from the back. In order to reach it you need to take the screen off, so this tutorial is only partially helpful for fixing the fingerprint scanner.
Danny Remi - Reply Share
hello y need a original battery cover for my motorola moto g7 plus can you help me $g$
Miguel Plascencia guzman - Reply Share
Where can I order the sensor from?
Sourabh Kapur - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 63
All Time: 4,178
