Motorola Moto G60S Fingerprint Sensor Replacement
  1. Motorola Moto G60S Fingerprint Sensor Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your phone and unplug any cables.
    Ask FixBot
  2. Motorola Moto G60S Fingerprint Sensor Replacement, Remove the SIM card tray: step 2, image 1 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Remove the SIM card tray: step 2, image 2 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Remove the SIM card tray: step 2, image 3 of 3
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the left edge of the phone.
    • Push the SIM eject tool into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
    Ask FixBot
  3. Motorola Moto G60S Fingerprint Sensor Replacement, Heat the right edge: step 3, image 1 of 1
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Ask FixBot
  4. Motorola Moto G60S Fingerprint Sensor Replacement, Insert an opening pick: step 4, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement, Insert an opening pick: step 4, image 2 of 2
    • Flip your phone over so the display is facing up.
    • Apply a suction handle to the middle of the display's left edge, as close to the edge as possible.
    • Place the tip of an opening pick in the small gap between the back cover and the display.
    • Pull up on the suction cup with a strong, steady force and push the opening pick down at a 45 degree angle until it slides into the gap between the back cover and the display.
    • If you're having a hard time inserting the pick, reheat the adhesive with an iOpener and try again.
    Ask FixBot
  5. Motorola Moto G60S Fingerprint Sensor Replacement, Slice the left adhesive: step 5, image 1 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Slice the left adhesive: step 5, image 2 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Slice the left adhesive: step 5, image 3 of 3
    • Both adhesive and clips secure the back cover.
    • During steps that involve sliding the opening pick, keep it angled down at a 45 degree angle.
    • Slide the pick along the left edge down to the bottom left corner, and then up to the top left corner, to release the clips and slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
    Ask FixBot
  6. Motorola Moto G60S Fingerprint Sensor Replacement, Heat the top edge: step 6, image 1 of 1
    • Flip your phone over and apply a heated iOpener to the back cover's top edge for two minutes.
    Ask FixBot
  7. Motorola Moto G60S Fingerprint Sensor Replacement: step 7, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement: step 7, image 2 of 2
    • Flip your phone over and rotate the pick around the top left corner.
    Ask FixBot
  8. Motorola Moto G60S Fingerprint Sensor Replacement: step 8, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement: step 8, image 2 of 2
    • Slide the pick along the top edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the top right corner.
    Ask FixBot
  9. Motorola Moto G60S Fingerprint Sensor Replacement: step 9, image 1 of 1
    • Flip your phone over and apply a heated iOpener to the back cover's left edge for two minutes.
    Ask FixBot
  10. Motorola Moto G60S Fingerprint Sensor Replacement: step 10, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement: step 10, image 2 of 2
    • Flip your phone over and rotate the pick around the top right corner.
    Ask FixBot
  11. Motorola Moto G60S Fingerprint Sensor Replacement: step 11, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement: step 11, image 2 of 2
    • Slide the pick along the right edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
    Ask FixBot
  12. Motorola Moto G60S Fingerprint Sensor Replacement: step 12, image 1 of 1
    • Flip your phone over and apply a heated iOpener to the back cover's bottom edge for two minutes.
    Ask FixBot
  13. Motorola Moto G60S Fingerprint Sensor Replacement: step 13, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement: step 13, image 2 of 2
    • Flip your phone over and rotate the pick around the bottom right corner.
    Ask FixBot
  14. Motorola Moto G60S Fingerprint Sensor Replacement: step 14, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement: step 14, image 2 of 2
    • Slide the opening pick along the bottom edge to release the clips and slice the adhesive.
    Ask FixBot
  15. Motorola Moto G60S Fingerprint Sensor Replacement: step 15, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement: step 15, image 2 of 2
    • Flip your phone over and apply a heated iOpener to the fingerprint sensor on the back cover for two minutes.
    Ask FixBot
  16. Motorola Moto G60S Fingerprint Sensor Replacement, Detach the fingerprint sensor: step 16, image 1 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Detach the fingerprint sensor: step 16, image 2 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Detach the fingerprint sensor: step 16, image 3 of 3
    • Adhesive secures the fingerprint sensor to the back case.
    • A fragile cable secures the fingerprint sensor to the motherboard. Be very careful during this step to avoid damaging the cable.
    • Press down on the fingerprint sensor with the flat end of a spudger or your finger.
    • While pressing down on the fingerprint sensor, gently pull up the bottom edge of the back cover until the sensor detaches.
    Ask FixBot
  17. Motorola Moto G60S Fingerprint Sensor Replacement, Remove the back cover: step 17, image 1 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Remove the back cover: step 17, image 2 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Remove the back cover: step 17, image 3 of 3
    • Lift the back cover up and remove it.
    • If the back cover is still stuck to the frame, slide an opening pick around the entire perimeter until the cover separates completely.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • Apply new adhesive to the perimeter of the underside of the back cover after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
    Ask FixBot
  18. Motorola Moto G60S Fingerprint Sensor Replacement, Detach the fingerprint sensor: step 18, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement, Detach the fingerprint sensor: step 18, image 2 of 2
    • The fingerprint reader is secured to the motherboard cover with light adhesive.
    • Insert the flat end of a spudger under the fingerprint sensor.
    • Gently pry up and detach the fingerprint sensor from the motherboard cover.
    • Don't try to remove the fingerprint sensor yet, as it's still attached to the motherboard by a delicate ribbon cable.
    Ask FixBot
  19. Motorola Moto G60S Fingerprint Sensor Replacement, Unfasten the motherboard cover: step 19, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement, Unfasten the motherboard cover: step 19, image 2 of 2
    • Use a Phillips screwdriver to remove the seven 3.9 mm screws securing the motherboard cover.
    Ask FixBot
  20. Motorola Moto G60S Fingerprint Sensor Replacement, Unclip the motherboard cover: step 20, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement, Unclip the motherboard cover: step 20, image 2 of 2
    • The motherboard cover is secured with tight clips.
    • Insert the flat end of a spudger in the gap between the frame and the bottom left corner of the motherboard cover.
    • Lift straight up with the spudger to release the clips securing the motherboard.
    • Don't pry against the battery, as this could damage it.
    • This may take take a few attempts. It you're having trouble, try gripping the spudger closer to the flat end.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
    Ask FixBot
  21. Motorola Moto G60S Fingerprint Sensor Replacement, Remove the motherboard cover: step 21, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement, Remove the motherboard cover: step 21, image 2 of 2
    • Pull the motherboard cover towards the top of the phone to remove it.
    • Make sure to avoid the fingerprint sensor cable when removing the cover, as it can easily rip.
    Ask FixBot
  22. Motorola Moto G60S Fingerprint Sensor Replacement, Disconnect the battery: step 22, image 1 of 2 Motorola Moto G60S Fingerprint Sensor Replacement, Disconnect the battery: step 22, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the battery cable's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Ask FixBot
  23. Motorola Moto G60S Fingerprint Sensor Replacement, Remove the fingerprint sensor: step 23, image 1 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Remove the fingerprint sensor: step 23, image 2 of 3 Motorola Moto G60S Fingerprint Sensor Replacement, Remove the fingerprint sensor: step 23, image 3 of 3
    Tool used on this step:
    Buy
    • Use the pointed end of a spudger to pry up and disconnect the fingerprint sensor's press connector.
    • There's no adhesive securing the fingerprint sensor to the motherboard. Be careful disconnecting the press connector, as it may eject the fingerprint sensor.
    • Use tweezers or your fingers to remove the fingerprint sensor.
    Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Spencer Day
188,072 Reputation
1,187 Guides authored
iFixit Member of iFixit
Staff
123 Members
25,718 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 405
