Motorola Moto G5s Plus Fingerprint Sensor Replacement
    1. Motorola Moto G5s Plus Fingerprint Sensor Replacement, Display: step 1, image 1 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement, Display: step 1, image 2 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement, Display: step 1, image 3 of 3
      • Power off the phone before you begin.
      • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
      • Spend equal amounts of time applying heat around the entire edge of the phone.
      Ask FixBot
    2. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 2, image 1 of 2 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 2, image 2 of 2
      • Attach the suction cup to the display slightly to the left of center.
      • Exert a moderate force to pull on the suction cup. The display will come loose.
      Ask FixBot
    3. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 3, image 1 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 3, image 2 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 3, image 3 of 3
      • Insert the opening tool inside the loosened edge.
      • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
      • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
      Ask FixBot
    4. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 4, image 1 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 4, image 2 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 4, image 3 of 3
      • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
      • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
      • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
      Ask FixBot
    5. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 5, image 1 of 2 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 5, image 2 of 2
      • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
      • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
      Ask FixBot
    6. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 6, image 1 of 2 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Grab the unscrewed metal plate with your blunt tweezers.
      • Slide the metal plate to the left and then out to remove it.
      • Removing the plate will expose the display assembly's connection to the phone's motherboard.
      Ask FixBot
    7. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 7, image 1 of 2 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 7, image 2 of 2
      • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
      Ask FixBot
    8. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 8, image 1 of 2 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 8, image 2 of 2
      • Lift up the detached right connector from its housing using blunt tweezers.
      • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
      Ask FixBot
    1. Motorola Moto G5s Plus Fingerprint Sensor Replacement, Fingerprint Sensor: step 9, image 1 of 1
      • Remove the nine black 5mm Torx-5 screws.
      • Remove the seven silver 5mm Torx-5 screws.
      Ask FixBot
    2. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 10, image 1 of 2 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 10, image 2 of 2
      • Remove the metal cover by prying underneath it with the opening tool.
      Ask FixBot
    3. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 11, image 1 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 11, image 2 of 3 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 11, image 3 of 3
      • Grab ahold of the fingerprint sensor and push it through the opening in the metal cover.
      Ask FixBot
    4. Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 12, image 1 of 2 Motorola Moto G5s Plus Fingerprint Sensor Replacement: step 12, image 2 of 2
      • Remove the fingerprint connector by gently prying underneath the connector with the opening tool.
      Ask FixBot
Aria Amini
155 Reputation
1 Guide authored
Cal Poly, Team S4-G5, White Fall 2018 Member of Cal Poly, Team S4-G5, White Fall 2018
CPSU-WHITE-F18S4G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 35
All Time: 1,413
