Motorola Moto G5 Front Camera Replacement
    1. Motorola Moto G5 Front Camera Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Back Cover: step 1, image 2 of 2
      • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
      • Pry with your fingernail or twist the spudger to release the back cover from the phone.
      Ask FixBot
    2. Motorola Moto G5 Front Camera Replacement: step 2, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 2, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 2, image 3 of 3
      • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
      Ask FixBot
    3. Motorola Moto G5 Front Camera Replacement: step 3, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 3, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 3, image 3 of 3
      • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
      Ask FixBot
    4. Motorola Moto G5 Front Camera Replacement: step 4, image 1 of 2 Motorola Moto G5 Front Camera Replacement: step 4, image 2 of 2
      • Lift the back cover and remove it from the phone.
      • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
      Ask FixBot
    1. Motorola Moto G5 Front Camera Replacement, Battery: step 5, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Battery: step 5, image 2 of 2
      • Insert your fingernail or the flat end of the spudger into the notch below the battery.
      • Pry with your fingernail or spudger until you free the battery from its recess.
      Ask FixBot
    2. Motorola Moto G5 Front Camera Replacement: step 6, image 1 of 1
      • Remove the battery.
      • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
      Ask FixBot
    1. Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: step 7, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: step 7, image 2 of 2
      • Remove the eight (8) 4mm screws with a Phillips screwdriver.
      Ask FixBot
    2. Motorola Moto G5 Front Camera Replacement: step 8, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 8, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 8, image 3 of 3
      • Pry the top motherboard cover off using a plastic opening tool.
      • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
      Ask FixBot
    3. Motorola Moto G5 Front Camera Replacement: step 9, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 9, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
      Ask FixBot
    1. Motorola Moto G5 Front Camera Replacement, Motherboard: step 10, image 1 of 1
      • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
      Ask FixBot
    2. Motorola Moto G5 Front Camera Replacement: step 11, image 1 of 1
      • Lift the motherboard up from the top of the phone.
      Ask FixBot
    3. Motorola Moto G5 Front Camera Replacement: step 12, image 1 of 1
      Buy
      • Unplug the back connector from the motherboard using tweezers.
      Ask FixBot
    1. Motorola Moto G5 Front Camera Replacement, Front Camera: step 13, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Front Camera: step 13, image 2 of 2
      Buy
      • Grab the connector with the tweezers and gently unplug the front camera from the motherboard.
      Ask FixBot
4 other people completed this guide.
Enosh Reeder
209 Reputation
1 Guide authored
Cal Poly, Team S2-G3, Livingston Winter 2018 Member of Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 104
All Time: 2,686
