Motorola Moto G4 Play Side Buttons Replacement
  1. Motorola Moto G4 Play Side Buttons Replacement, Battery: step 1, image 1 of 3 Motorola Moto G4 Play Side Buttons Replacement, Battery: step 1, image 2 of 3 Motorola Moto G4 Play Side Buttons Replacement, Battery: step 1, image 3 of 3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Side Buttons Replacement: step 2, image 1 of 3 Motorola Moto G4 Play Side Buttons Replacement: step 2, image 2 of 3 Motorola Moto G4 Play Side Buttons Replacement: step 2, image 3 of 3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Side Buttons Replacement: step 3, image 1 of 3 Motorola Moto G4 Play Side Buttons Replacement: step 3, image 2 of 3 Motorola Moto G4 Play Side Buttons Replacement: step 3, image 3 of 3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Motorola Moto G4 Play Side Buttons Replacement, Midframe: step 4, image 1 of 3 Motorola Moto G4 Play Side Buttons Replacement, Midframe: step 4, image 2 of 3 Motorola Moto G4 Play Side Buttons Replacement, Midframe: step 4, image 3 of 3
    • Remove any SIM card and/or memory card present using your hand.
  5. Motorola Moto G4 Play Side Buttons Replacement: step 5, image 1 of 2 Motorola Moto G4 Play Side Buttons Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  6. Motorola Moto G4 Play Side Buttons Replacement: step 6, image 1 of 1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  7. Motorola Moto G4 Play Side Buttons Replacement: step 7, image 1 of 3 Motorola Moto G4 Play Side Buttons Replacement: step 7, image 2 of 3 Motorola Moto G4 Play Side Buttons Replacement: step 7, image 3 of 3
    • Remove the back panel assembly with your hands.
  8. Motorola Moto G4 Play Side Buttons Replacement, Side Buttons: step 8, image 1 of 1
    Buy
    • Remove the volume button by pushing the round tips out using the tweezers (or a pen if you don't have tweezers).
  9. Motorola Moto G4 Play Side Buttons Replacement: step 9, image 1 of 1
    • Remove the power button by pushing the round tip out using the tweezers (or a pen if you don't have tweezers).
6 other people completed this guide.
Francisco Hernández
741 Reputation
2 Guides authored
USF Tampa, Team S17-G4, Boczar Spring 2018 Member of USF Tampa, Team S17-G4, Boczar Spring 2018
USFT-BOCZAR-S18S17G4
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 71
All Time: 2,841
