Motorola Moto G4 Play Screen Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
76
All Time:
5,783
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
Use this guide to replace a broken or malfunctioning screen. When removing the screen, make sure to wear safety glasses.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
Note: Microwave only one iOpener at a time for no more than 30 seconds, and make sure to not microwave it more than once within two minutes.
Tools
    1. Motorola Moto G4 Play Screen Replacement, Battery: step 1, image 1 of 3 Motorola Moto G4 Play Screen Replacement, Battery: step 1, image 2 of 3 Motorola Moto G4 Play Screen Replacement, Battery: step 1, image 3 of 3
      • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
      Ask FixBot
    2. Motorola Moto G4 Play Screen Replacement: step 2, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 2, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 2, image 3 of 3
      • Lift the case by the nearest corner to the divot and remove it from the phone.
      Ask FixBot
    3. Motorola Moto G4 Play Screen Replacement: step 3, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 3, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 3, image 3 of 3
      • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
      • Remove battery from your phone.
      Ask FixBot
    1. Motorola Moto G4 Play Screen Replacement, Midframe: step 4, image 1 of 3 Motorola Moto G4 Play Screen Replacement, Midframe: step 4, image 2 of 3 Motorola Moto G4 Play Screen Replacement, Midframe: step 4, image 3 of 3
      • Remove any SIM card and/or memory card present using your hand.
      Ask FixBot
    2. Motorola Moto G4 Play Screen Replacement: step 5, image 1 of 2 Motorola Moto G4 Play Screen Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the small silicon cover at the bottom right of the camera using tweezers.
      Ask FixBot
    3. Motorola Moto G4 Play Screen Replacement: step 6, image 1 of 1
      • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
      • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
      Ask FixBot
    4. Motorola Moto G4 Play Screen Replacement: step 7, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 7, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 7, image 3 of 3
      • Remove the back panel assembly with your hands.
      Ask FixBot
    1. Motorola Moto G4 Play Screen Replacement, Rear Camera: step 8, image 1 of 3 Motorola Moto G4 Play Screen Replacement, Rear Camera: step 8, image 2 of 3 Motorola Moto G4 Play Screen Replacement, Rear Camera: step 8, image 3 of 3
      • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
      Ask FixBot
    2. Motorola Moto G4 Play Screen Replacement: step 9, image 1 of 1
      Buy
      • After detaching the connector, carefully remove the camera using tweezers. If you don't have tweezers, use your hands.
      Ask FixBot
    1. Motorola Moto G4 Play Screen Replacement, Charging Port: step 10, image 1 of 2 Motorola Moto G4 Play Screen Replacement, Charging Port: step 10, image 2 of 2
      Buy
      • Use tweezers to pop up the antenna wire.
      Ask FixBot
    2. Motorola Moto G4 Play Screen Replacement: step 11, image 1 of 2 Motorola Moto G4 Play Screen Replacement: step 11, image 2 of 2
      • Use the flat end of a spudger to pry up on the connector at the bottom of the battery space.
      Ask FixBot
    3. Motorola Moto G4 Play Screen Replacement: step 12, image 1 of 1
      • Remove the two (2) 3mm Phillips PH000 screws securing the charging port.
      Ask FixBot
    4. Motorola Moto G4 Play Screen Replacement: step 13, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 13, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 13, image 3 of 3
      • Insert the tweezers under the vibrator and gently lift up the whole part.
      Ask FixBot
    5. Motorola Moto G4 Play Screen Replacement: step 14, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 14, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 14, image 3 of 3
      • Pop up on the vibrator's connector to separate it from the charging port.
      Ask FixBot
    1. Motorola Moto G4 Play Screen Replacement, Screen: step 15, image 1 of 3 Motorola Moto G4 Play Screen Replacement, Screen: step 15, image 2 of 3 Motorola Moto G4 Play Screen Replacement, Screen: step 15, image 3 of 3
      • Using an opening tool, pry up one of the connectors to the left of where the sim card was located.
      Ask FixBot
    2. Motorola Moto G4 Play Screen Replacement: step 16, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 16, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 16, image 3 of 3
      • Pry up the next connector located right on top of the previous one.
      Ask FixBot
    3. Motorola Moto G4 Play Screen Replacement: step 17, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 17, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 17, image 3 of 3
      • Using the Phillips screwdriver, remove the screw that's found next to the speaker on the top left of the phone.
      Ask FixBot
    4. Motorola Moto G4 Play Screen Replacement: step 18, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 18, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 18, image 3 of 3
      • Using the plastic opening tool, carefully pry up the motherboard.
      Ask FixBot
    5. Motorola Moto G4 Play Screen Replacement: step 19, image 1 of 2 Motorola Moto G4 Play Screen Replacement: step 19, image 2 of 2
      • Pull up the cable that connects the motherboard and the charging port.
      • It's on the side that's closer to the motherboard, you might need to push the cable down first, and then pull it up.
      Ask FixBot
    6. Motorola Moto G4 Play Screen Replacement: step 20, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 20, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 20, image 3 of 3
      • Pry up the frontal speaker with a plastic opening tool.
      Ask FixBot
    7. Motorola Moto G4 Play Screen Replacement: step 21, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 21, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 21, image 3 of 3
      • Peel the black tape up with a plastic opening tool and or your fingers.
      Ask FixBot
    8. Motorola Moto G4 Play Screen Replacement: step 22, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 22, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 22, image 3 of 3
      • Peel the flexible black cable using a plastic opening tool and or your fingers.
      Ask FixBot
    9. Motorola Moto G4 Play Screen Replacement: step 23, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 23, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 23, image 3 of 3
      • Peel up the small tape that's connected to the screen with a plastic opening tool.
      Ask FixBot
    10. Motorola Moto G4 Play Screen Replacement: step 24, image 1 of 2 Motorola Moto G4 Play Screen Replacement: step 24, image 2 of 2
      • Place an iOpener on the edges to soften the screen adhesive.
      Ask FixBot
    11. Motorola Moto G4 Play Screen Replacement: step 25, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 25, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 25, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Insert the Jimmy knife through the edge.
      • Place a plastic card so that the adhesive doesn't stick back again.
      • Go around the edges of the device with the Jimmy knife until all the adhesive has been removed.
      Ask FixBot
    12. Motorola Moto G4 Play Screen Replacement: step 26, image 1 of 3 Motorola Moto G4 Play Screen Replacement: step 26, image 2 of 3 Motorola Moto G4 Play Screen Replacement: step 26, image 3 of 3
      • Pull up on the LCD screen with your hands and remove it.
      Ask FixBot
10 other people completed this guide.
Yordan Gil
447 Reputation
1 Guide authored
USF Tampa, Team S17-G4, Boczar Spring 2018 Member of USF Tampa, Team S17-G4, Boczar Spring 2018
USFT-BOCZAR-S18S17G4
4 Members
72 Guides authored
4 Guide Comments
The phone I just tried to fix had two digitizer connectors just like the one in this procedure, but all the replacement parts I can find on ebay and aliexpress etc. which claim to be for XT1601 - XT1609 have just a single connector. Any thoughts about why that would be?
jrhooker - Reply Share
The smaller one is from the power and Volume buttons and needs tobe transfered to the new display if you bought one with Frame (which makes it much easier)
Marko Käppler - Reply Share
I had to figure out that out myself. Yes, you will need to transfer the connector from the old frame to the new frame. I should also add, the frame I got had no buttons, so I had to get them from the old phone.
Joshua Rieth - Reply Share
Good guide though I could not see the purpose of removing items 20, 21 & 22
pauldmallett - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 76
All Time: 5,783
