Motorola Moto G4 Lens Replacement
    1. Motorola Moto G4 Lens Replacement, Lens: step 1, image 1 of 2 Motorola Moto G4 Lens Replacement, Lens: step 1, image 2 of 2
      • Place your thumb in the indent located at bottom left corner of the back cover.
      • The cover will pop up and begin to lift
      • Continue to slide your fingers up the sides to remove the back cover
      Ask FixBot
    2. Motorola Moto G4 Lens Replacement: step 2, image 1 of 2 Motorola Moto G4 Lens Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the gray plastic surrounding the camera lens with a pair of tweezers.
      • There will be a lot of glue and you may have to pull hard on the plastic piece
      Ask FixBot
    3. Motorola Moto G4 Lens Replacement: step 3, image 1 of 2 Motorola Moto G4 Lens Replacement: step 3, image 2 of 2
      • Slide a pair of tweezers under and around the lens to loosen it.
      • Pulls the lens towards you to remove.
      • There will be glue under the lens. You may have to pull hard to remove the lens
      Ask FixBot
6 other people completed this guide.
Kierra Schau
1,511 Reputation
4 Guides authored
USF Tampa, Team S11-G2, Passmore Fall 2017 Member of USF Tampa, Team S11-G2, Passmore Fall 2017
USFT-PASSMORE-F17S11G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 114
All Time: 2,855
