Motorola Moto G Power 2022 Front Camera Replacement
    1. Motorola Moto G Power 2022 Front Camera Replacement, Front Camera: step 1, image 1 of 2 Motorola Moto G Power 2022 Front Camera Replacement, Front Camera: step 1, image 2 of 2
      • Power off the phone by holding the volume and power buttons simultaneously.
      • Insert the end of a paperclip or a SIM card eject tool into the small hole to eject the SIM tray, then remove it.
      Ask FixBot
    2. Motorola Moto G Power 2022 Front Camera Replacement: step 2, image 1 of 2 Motorola Moto G Power 2022 Front Camera Replacement: step 2, image 2 of 2
      • Slide an opening pick around the perimeter of the phone to break through and loosen the adhesive holding the outer case in place.
      • Use an opening tool to release the clips securing the front and back casing together.
      • Don't remove the case yet!
      Ask FixBot
    3. Motorola Moto G Power 2022 Front Camera Replacement: step 3, image 1 of 3 Motorola Moto G Power 2022 Front Camera Replacement: step 3, image 2 of 3 Motorola Moto G Power 2022 Front Camera Replacement: step 3, image 3 of 3
      • Heat an iOpener and set it on the fingerprint sensor to loosen the adhesive.
      • Heat the iOpener for 30 seconds at a time, and hold it on the phone for 1-2 minutes.
      • Press on the Motorola Logo and remove the outer case.
      • If the adhesive has loosened, it should pop right off.
      Ask FixBot
    4. Motorola Moto G Power 2022 Front Camera Replacement: step 4, image 1 of 3 Motorola Moto G Power 2022 Front Camera Replacement: step 4, image 2 of 3 Motorola Moto G Power 2022 Front Camera Replacement: step 4, image 3 of 3
      • Use a Torx T5 screwdriver to remove nineteen 3.9 mm screws from the midframe.
      • Be careful not to lose any of the screws!
      Ask FixBot
    5. Motorola Moto G Power 2022 Front Camera Replacement: step 5, image 1 of 2 Motorola Moto G Power 2022 Front Camera Replacement: step 5, image 2 of 2
      • Remove the plastic cover from the motherboard.
      • It should come off easily after the screws are removed.
      Ask FixBot
    6. Motorola Moto G Power 2022 Front Camera Replacement: step 6, image 1 of 3 Motorola Moto G Power 2022 Front Camera Replacement: step 6, image 2 of 3 Motorola Moto G Power 2022 Front Camera Replacement: step 6, image 3 of 3
      • Use your fingers or tweezers to gently peel off the the adhesive with the front camera.
      • It should all come off in one piece.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 30
All Time: 215
