Motorola Moto G Power (2020) Fingerprint Sensor Replacement
    1. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Back Case: step 1, image 1 of 1
      • Position a suction cup securely on the back panel of the device.
      • Insert the opening pick into both sides of the phone and carefully slide it along to open the back panel of the device.
      • Do not fully remove the back panel; disconnect the fingerprint sensor first.
      Ask FixBot
    2. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: step 2, image 1 of 1
      • Apply gentle pressure to the fingerprint sensor with your finger to detach it from the back panel.
      • You may need to apply firm pressure to remove the circular sensor from the panel.
      Ask FixBot
    3. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: step 3, image 1 of 1
      • Fully remove the back panel from the device.
      Ask FixBot
    1. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Fingerprint Sensor: step 4, image 1 of 1
      • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
      Ask FixBot
    2. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: step 5, image 1 of 3 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: step 5, image 2 of 3 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: step 5, image 3 of 3
      • Use the spudger to gently lift the cover.
      • If needed, use the spudger's tip against a corner of the cover to help lift it.
      • Set the back cover aside.
      • DO NOT use excessive force when lifting up the back cover.
      Ask FixBot
    3. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: step 6, image 1 of 1
      • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
      • WARNING: Handle the sensor cable with care; it can be easily damaged.
      Ask FixBot
    4. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: step 7, image 1 of 1
      • Carefully remove the fingerprint sensor from the device and set it aside.
      • Do not use excessive force when lifting the back cover or any other component.
      Ask FixBot
Harry Jung
781 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 57
All Time: 1,887
