Motorola Moto G Play (2021) Display Panel Replacement
  1. Motorola Moto G Play (2021) Display Panel Replacement, Heat the left edge: step 1, image 1 of 1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the left edge of the cover for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Ask FixBot
  2. Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: step 2, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: step 2, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the back cover, as close to the center of the left edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
    Ask FixBot
  3. Motorola Moto G Play (2021) Display Panel Replacement, Slice the right adhesive: step 3, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the right adhesive: step 3, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the right adhesive: step 3, image 3 of 3
    • Slide your opening pick back and forth along the left edge to slice through the adhesive.
    • Leave the pick in at the bottom left corner to prevent the adhesive from resealing.
    Ask FixBot
  4. Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: step 4, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: step 4, image 2 of 2
    • Insert and slide a second opening pick to the bottom right corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
    • Repeat this process for the right and top edges of the cover.
    Ask FixBot
  5. Motorola Moto G Play (2021) Display Panel Replacement, Dislodge the fingerprint reader: step 5, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Dislodge the fingerprint reader: step 5, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Dislodge the fingerprint reader: step 5, image 3 of 3
    • The fingerprint reader is connected to the motherboard by a fragile cable. You must free it before pulling the cover off.
    • Grab and lift the bottom edge of the cover.
    • As you lift the back cover, press and unstick the fingerprint reader from it.
    Ask FixBot
  6. Motorola Moto G Play (2021) Display Panel Replacement, Remove the back cover: step 6, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the back cover: step 6, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the back cover: step 6, image 3 of 3
    • Grab and remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
    Ask FixBot
  7. Motorola Moto G Play (2021) Display Panel Replacement, Reposition the fingerprint reader: step 7, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Reposition the fingerprint reader: step 7, image 2 of 2
    • Flip the fingerprint reader to the left, away from the phone.
    • Don't fold or sharply bend the ribbon cable.
    Ask FixBot
  8. Motorola Moto G Play (2021) Display Panel Replacement, Unfasten the motherboard cover: step 8, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Unfasten the motherboard cover: step 8, image 2 of 2
    • Use your Phillips screwdriver to remove the twelve 3.9 mm-long screws securing the motherboard cover.
    Ask FixBot
  9. Motorola Moto G Play (2021) Display Panel Replacement, Pry the motherboard cover: step 9, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Pry the motherboard cover: step 9, image 2 of 2
    • Insert the pointed end of a spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry the cover upward until you can grab it with your fingers.
    Ask FixBot
  10. Motorola Moto G Play (2021) Display Panel Replacement, Remove the motherboard cover: step 10, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Remove the motherboard cover: step 10, image 2 of 2
    • Grab the bottom edge of the motherboard cover and remove it from the frame.
    Ask FixBot
  11. Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the battery: step 11, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the battery: step 11, image 2 of 2
    • Use the pointed end of your spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Ask FixBot
  12. Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the fingerprint reader: step 12, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the fingerprint reader: step 12, image 2 of 2
    • Use the pointed end of your spudger to pry and disconnect the fingerprint reader's press connector.
    • The gold arrow indicates the direction to pry from.
    Ask FixBot
  13. Motorola Moto G Play (2021) Display Panel Replacement, Remove the fingerprint reader: step 13, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Remove the fingerprint reader: step 13, image 2 of 2
    Tool used on this step:
    Buy
    • Use your fingers or tweezers to remove the fingerprint reader.
    • Be careful while handling the fragile ribbon cable.
    Ask FixBot
  14. Motorola Moto G Play (2021) Display Panel Replacement, Soften the adhesive with heat: step 14, image 1 of 1
    • Heat an iOpener and apply it to the left edge of the screen for about two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Ask FixBot
  15. Motorola Moto G Play (2021) Display Panel Replacement, Soften the adhesive with isopropyl alcohol: step 15, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Soften the adhesive with isopropyl alcohol: step 15, image 2 of 2
    • Additionally, you may use highly-concentrated isopropyl alcohol (over 90%) to further loosen the adhesive securing the battery.
    • Apply the isopropyl alcohol into the gaps between the sides of the battery and the frame.
    Ask FixBot
  16. Motorola Moto G Play (2021) Display Panel Replacement, Reposition the graphite film: step 16, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Reposition the graphite film: step 16, image 2 of 2
    • Fold the graphite heat dispersion film toward the top of the battery.
    Ask FixBot
  17. Motorola Moto G Play (2021) Display Panel Replacement, Pry the battery: step 17, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Pry the battery: step 17, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Pry the battery: step 17, image 3 of 3
    • Place a suction handle on the center of the battery.
    • Insert an opening pick between the right edge of the battery and the frame.
    • Use a steady force to pull on the suction handle and simultaneously pry with the pick.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that is required to free it from the frame.
    • Apply more heat or isopropyl alcohol if the battery readheres.
    Ask FixBot
  18. Motorola Moto G Play (2021) Display Panel Replacement, Remove the battery: step 18, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the battery: step 18, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the battery: step 18, image 3 of 3
    • Remove the battery from its recess.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Use this guide to install a battery with custom-cut adhesives, or use this guide to install a battery with an adhesive sheet.
    Ask FixBot
  19. Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the display: step 19, image 1 of 2 Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the display: step 19, image 2 of 2
    • Use the pointed end of your spudger to pry and disconnect the display cable's press connector.
    Ask FixBot
  20. Motorola Moto G Play (2021) Display Panel Replacement, Soften the display cable's adhesive: step 20, image 1 of 1
    • Heat an iOpener and apply it to the display cable for two minutes.
    • The iOpener may stick to the residue left over from the battery. Clean the surrounding surface with highly-concentrated isopropyl alcohol (over 90%) to prevent this.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
    Ask FixBot
  21. Motorola Moto G Play (2021) Display Panel Replacement, Loosen the display cable: step 21, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Loosen the display cable: step 21, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Loosen the display cable: step 21, image 3 of 3
    • Grab the display cable near the connector.
    • Don't attempt to completely remove the cable.
    • Peel the cable toward the bottom of the phone until it's completely separated from the frame.
    Ask FixBot
  22. Motorola Moto G Play (2021) Display Panel Replacement, Heat the bottom edge: step 22, image 1 of 1
    • Heat an iOpener and apply it to the bottom of the screen for about two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage, and the exterior coating of the phone will wrinkle under high temperatures.
    Ask FixBot
  23. Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: step 23, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: step 23, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: step 23, image 3 of 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a gap between the glass and the frame.
    • If the glass does not separate, apply more heat and try again.
    Ask FixBot
  24. Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: step 24, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: step 24, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: step 24, image 3 of 3
    • Don't insert the opening pick deeper than 2 mm, as you may delaminate the display panel.
    • Slide the pick back and forth to separate the bottom edge's adhesive.
    Ask FixBot
  25. Motorola Moto G Play (2021) Display Panel Replacement, Slice the left adhesive: step 25, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the left adhesive: step 25, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the left adhesive: step 25, image 3 of 3
    • Slide your opening pick to the top left corner to separate the left edge's adhesive.
    • Repeat this process for the top and right edges to completely separate the display panel from the frame.
    Ask FixBot
  26. Motorola Moto G Play (2021) Display Panel Replacement: step 26, image 1 of 3 Motorola Moto G Play (2021) Display Panel Replacement: step 26, image 2 of 3 Motorola Moto G Play (2021) Display Panel Replacement: step 26, image 3 of 3
    • Grab and pull the bottom of the display panel down and away from the frame, making sure to thread the display cable through its slot.
    • Once the display cable is free, remove the panel from the frame.
    Ask FixBot
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
2 other people completed this guide.
Clay Eickemeyer
103,258 Reputation
476 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 57
All Time: 1,955
