Motorola Moto G 3rd Generation Display Replacement
Views: 59K
View statistics:
Past 24 Hours:
4
Past 7 Days:
44
Past 30 Days:
168
All Time:
59,385
Comments: 33
13 comments on steps, 20 guide comments.
Go to guide comments
Completed: 52
52 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to remove the LCD touchscreen from your Moto G 3rd Generation. Follow these step for access into the phone's interior as well as for replacing the touchscreen. This guide requires the use of a heat gun or an iOpener.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
Parts
  • Tesa 61395 Double-Sided Tape
    4.9
Tools
Video Overview
    1. Motorola Moto G 3rd Generation Display Replacement, Display: step 1, image 1 of 2 Motorola Moto G 3rd Generation Display Replacement, Display: step 1, image 2 of 2
      • Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
      • Make sure to fully power off the phone before you begin disassembly.
      Ask FixBot
    2. Motorola Moto G 3rd Generation Display Replacement: step 2, image 1 of 2 Motorola Moto G 3rd Generation Display Replacement: step 2, image 2 of 2
      • Use a heat gun or an iOpener as a heating tool. This guide explains how to use the iOpener.
      • Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
      • Do not let the iOpener/heat gun remain on one spot for too long. Excess heat can damage the phone.
      • When reassembling the phone, use the iOpener/heat gun to help the adhesive fuse to the new screen. Heat the screen edges, apply pressure to the screen, and hold the screen in place until it is secure.
      Ask FixBot
    3. Motorola Moto G 3rd Generation Display Replacement: step 3, image 1 of 3 Motorola Moto G 3rd Generation Display Replacement: step 3, image 2 of 3 Motorola Moto G 3rd Generation Display Replacement: step 3, image 3 of 3
      • As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
      • Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
      • Avoid damaging the LCD screen connector while prying along the screen edges. It is located on the left edge of the phone, across from the volume controls.
      • During reassembly, new adhesive may need to be applied over the old adhesive to properly secure the screen.
      Ask FixBot
    4. Motorola Moto G 3rd Generation Display Replacement: step 4, image 1 of 3 Motorola Moto G 3rd Generation Display Replacement: step 4, image 2 of 3 Motorola Moto G 3rd Generation Display Replacement: step 4, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
      • Pull the display cable from its socket on the motherboard.
      • When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
      Ask FixBot
52 other people completed this guide.
Ahnaf Siddiqui
663 Reputation
1 Guide authored
USF Tampa, Team 1-3, Nance Spring 2016 Member of USF Tampa, Team 1-3, Nance Spring 2016
USFT-NANCE-S16S1G3
4 Members
72 Guides authored
20 Guide Comments
If your original screen has any adhesive tape on it's back (near to where the flat cable connects to the board), remove it from the original and put on the replacement piece, i've spent a lot of hours trying to undestand why my replacement screen worked fine out of the phone, but had some problems after puting it on the phone. After a lot of time i noticed this tape and did what i said, and the problem stoped, aparently is some kind short circuit betwen board and the screen aluminum back. Sorry bad english.
Leonardo Assef - Reply Share
Could you explain where the addhesive was a little bit more? I have my screen falling off from that corner and I've tried adding more addhesive but still... Wondering if the replacement is faulty.. I don't have the original anymore
rpalesh - Reply Share
Thank you soooooo much! I just had the same problem! many thanks for posting und best wishes. You are a great human being!
Felix Eikenberg - Reply Share
I had the same problem, now i ordered better adhesive. where is this tape? Do you have a picture?
sebastianwolz - Reply Share
In my case it was a yellow stripe unter the ZIF connector that prevents the socket from connecting with the back of the screen.
Julian Zimmermann - Reply Share
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 168
All Time: 59,385
