Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use the Pry tool to disconnect the Front Camera, found in the upper right corner, from the motherboard.
Tool used on this step:Tweezers$4.99
Remove the camera from the phone by using the tweezers.
To reassemble, follow the steps in reverse.
4 other people completed this guide.
