Motorola Moto E6 Plus Display Replacement
    1. Motorola Moto E6 Plus Display Replacement, Unclip the back cover: step 1, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Unclip the back cover: step 1, image 2 of 2
      • Use an opening tool or your fingernail to pry the back cover away from the frame using the notch at the bottom right corner.
      Ask FixBot
    2. Motorola Moto E6 Plus Display Replacement, Unclip the right edge: step 2, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Unclip the right edge: step 2, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Unclip the right edge: step 2, image 3 of 3
      • Use an opening tool or your fingernail to release the clips on the right edge by sliding up and around the top right corner.
      Ask FixBot
    3. Motorola Moto E6 Plus Display Replacement, Unclip the top edge: step 3, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Unclip the top edge: step 3, image 2 of 2
      • Continue to slide the opening tool or your fingernail across the top edge to release the clips securing the back cover to the frame.
      Ask FixBot
    4. Motorola Moto E6 Plus Display Replacement, Unclip the left edge: step 4, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Unclip the left edge: step 4, image 2 of 2
      • Continue to slide the opening tool or your fingernail down the left edge to release the clips.
      Ask FixBot
    5. Motorola Moto E6 Plus Display Replacement, Remove the back cover: step 5, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Remove the back cover: step 5, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Remove the back cover: step 5, image 3 of 3
      • Remove the back cover.
      Ask FixBot
    1. Motorola Moto E6 Plus Display Replacement, Remove the battery: step 6, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Remove the battery: step 6, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Remove the battery: step 6, image 3 of 3
      • Use a spudger or your fingernail to pry the battery up using the notch near the bottom right corner.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Remove the battery.
      Ask FixBot
    1. Motorola Moto E6 Plus Display Replacement, Remove the screws: step 7, image 1 of 1
      • Use a Torx T3 driver to remove the three 3.6 mm-long screws securing the loudspeaker to the frame.
      • Use a Phillips screwdriver to remove the four 3.1 mm-long screws.
      Ask FixBot
    2. Motorola Moto E6 Plus Display Replacement, Unclip the loudspeaker: step 8, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Unclip the loudspeaker: step 8, image 2 of 2
      • Use a spudger to pry up the loudspeaker from the frame.
      • If you are having trouble releasing the clips securing the loudspeaker to the frame, use a spudger to pry around the loudspeaker to loosen it.
      Ask FixBot
    3. Motorola Moto E6 Plus Display Replacement, Remove the loudspeaker: step 9, image 1 of 1
      • Remove the loudspeaker.
      Ask FixBot
    1. Motorola Moto E6 Plus Display Replacement, Remove the charging port insulator: step 10, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Remove the charging port insulator: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to remove the charging port insulator.
      • The charging port insulator may have come off with the loudspeaker.
      Ask FixBot
    2. Motorola Moto E6 Plus Display Replacement, Disconnect the coaxial cable: step 11, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Disconnect the coaxial cable: step 11, image 2 of 2
      • Use the pointed end of a spudger to disconnect the coaxial cable by lifting straight up as close to the connector as possible.
      Ask FixBot
    3. Motorola Moto E6 Plus Display Replacement, Disconnect the motherboard flex cable: step 12, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Disconnect the motherboard flex cable: step 12, image 2 of 2
      • Use the flat end of a spudger to disconnect the motherboard flex cable by lifting straight up on the press connector.
      Ask FixBot
    4. Motorola Moto E6 Plus Display Replacement, Loosen the adhesive: step 13, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Loosen the adhesive: step 13, image 2 of 2
      • Heat an iOpener and apply it to the bottom edge of the screen for 30 seconds.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      • Apply a few drops of high concentration (over 90%) isopropyl alcohol underneath the vibration motor to loosen the adhesive securing it to the frame.
      • Tilt your phone to allow the isopropyl alcohol to flow underneath the vibration motor.
      Ask FixBot
    5. Motorola Moto E6 Plus Display Replacement, Remove the daughterboard assembly: step 14, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Remove the daughterboard assembly: step 14, image 2 of 2
      • Use an opening pick to peel the vibration motor off the frame.
      Ask FixBot
    6. Motorola Moto E6 Plus Display Replacement: step 15, image 1 of 3 Motorola Moto E6 Plus Display Replacement: step 15, image 2 of 3 Motorola Moto E6 Plus Display Replacement: step 15, image 3 of 3
      • Use an opening pick to peel the daughterboard assembly off the frame starting from the left edge.
      • Insert an opening pick under the bottom right edge to cut the remaining adhesive.
      Ask FixBot
    7. Motorola Moto E6 Plus Display Replacement: step 16, image 1 of 1
      • Remove the daughterboard assembly which includes the vibration motor and the charging port.
      Ask FixBot
    1. Motorola Moto E6 Plus Display Replacement, Remove the SIM and SD cards: step 17, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Remove the SIM and SD cards: step 17, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Remove the SIM and SD cards: step 17, image 3 of 3
      • Use a spudger or your fingernail to remove the Micro SD card, the Micro SIM card, and the Nano SIM card.
      Ask FixBot
    2. Motorola Moto E6 Plus Display Replacement, Remove the white sticker: step 18, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Remove the white sticker: step 18, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the sticker covering the screw below the audio jack port.
      Ask FixBot
    3. Motorola Moto E6 Plus Display Replacement, Remove the screws: step 19, image 1 of 1
      • Use a Torx T3 driver to remove the five 3.6 mm-long screws securing the motherboard cover to the frame.
      • Use a Phillips screwdriver to remove the two 3.1 mm-long screws.
      Ask FixBot
    4. Motorola Moto E6 Plus Display Replacement, Peel back the button sticker: step 20, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Peel back the button sticker: step 20, image 2 of 2
      • Use a pair of tweezers to peel back the sticker covering the volume buttons.
      Ask FixBot
    5. Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 21, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 21, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 21, image 3 of 3
      • Use an opening tool to release the clip to the left of the motherboard flex cable.
      Ask FixBot
    6. Motorola Moto E6 Plus Display Replacement: step 22, image 1 of 2 Motorola Moto E6 Plus Display Replacement: step 22, image 2 of 2
      • Insert a spudger along the left edge of the motherboard cover to loosen the clips.
      Ask FixBot
    7. Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 23, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 23, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 23, image 3 of 3
      • Use an opening tool to release the clip next to the rear cameras.
      Ask FixBot
    8. Motorola Moto E6 Plus Display Replacement: step 24, image 1 of 3 Motorola Moto E6 Plus Display Replacement: step 24, image 2 of 3 Motorola Moto E6 Plus Display Replacement: step 24, image 3 of 3
      • Use a pair of tweezers to peel off the sticker on the top edge of the motherboard cover.
      Ask FixBot
    9. Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 25, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Pry up the motherboard cover: step 25, image 2 of 2
      • Use a spudger to lift up the left edge of the motherboard cover to loosen the clips.
      Ask FixBot
    10. Motorola Moto E6 Plus Display Replacement, Dislodge the fingerprint sensor: step 26, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Dislodge the fingerprint sensor: step 26, image 2 of 2
      • Use a spudger to push and dislodge the fingerprint sensor off of the motherboard cover.
      • The fingerprint sensor is secured to the underside of the motherboard cover with some light adhesive.
      Ask FixBot
    11. Motorola Moto E6 Plus Display Replacement, Remove the motherboard cover: step 27, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Remove the motherboard cover: step 27, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Remove the motherboard cover: step 27, image 3 of 3
      • Use your fingers to twist the motherboard cover counterclockwise to release the clips securing the motherboard cover.
      Ask FixBot
    12. Motorola Moto E6 Plus Display Replacement: step 28, image 1 of 2 Motorola Moto E6 Plus Display Replacement: step 28, image 2 of 2
      • Remove the motherboard cover.
      Ask FixBot
    1. Motorola Moto E6 Plus Display Replacement, Disconnect the motherboard flex cable: step 29, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Disconnect the motherboard flex cable: step 29, image 2 of 2
      Ask FixBot
    2. Motorola Moto E6 Plus Display Replacement, Disconnect the button ribbon cable: step 30, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Disconnect the button ribbon cable: step 30, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Disconnect the button ribbon cable: step 30, image 3 of 3
      Buy
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button ZIF connector.
      • Use a pair of tweezers to pull the button ribbon cable straight out of the connector.
      Ask FixBot
    3. Motorola Moto E6 Plus Display Replacement, Disconnect the IR sensor: step 31, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Disconnect the IR sensor: step 31, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Disconnect the IR sensor: step 31, image 3 of 3
      • Use the pointed end of a spudger to pry the IR sensor out of the frame.
      • Remove the IR sensor gasket from the frame.
      Ask FixBot
    4. Motorola Moto E6 Plus Display Replacement, Remove the stickers: step 32, image 1 of 2 Motorola Moto E6 Plus Display Replacement, Remove the stickers: step 32, image 2 of 2
      • Use a pair of tweezers to peel off the tape covering the right motherboard screw.
      Ask FixBot
    5. Motorola Moto E6 Plus Display Replacement: step 33, image 1 of 2 Motorola Moto E6 Plus Display Replacement: step 33, image 2 of 2
      • Use a pair of tweezers to peel off the tape covering the left motherboard screw.
      Ask FixBot
    6. Motorola Moto E6 Plus Display Replacement, Remove the motherboard: step 34, image 1 of 1
      • Use a Phillips screwdriver to remove the two 3.1 mm-long screws securing the motherboard to the frame.
      • Do not attempt to completely remove the motherboard until the coaxial cable is disconnected.
      Ask FixBot
    7. Motorola Moto E6 Plus Display Replacement: step 35, image 1 of 3 Motorola Moto E6 Plus Display Replacement: step 35, image 2 of 3 Motorola Moto E6 Plus Display Replacement: step 35, image 3 of 3
      • Flip the motherboard assembly over.
      Ask FixBot
    8. Motorola Moto E6 Plus Display Replacement: step 36, image 1 of 2 Motorola Moto E6 Plus Display Replacement: step 36, image 2 of 2
      • Use the pointed end of a spudger to disconnect the coaxial cable by prying up on the cable as close to the connector as possible.
      Ask FixBot
    9. Motorola Moto E6 Plus Display Replacement: step 37, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    10. Motorola Moto E6 Plus Display Replacement, Remove the earpiece speaker: step 38, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Remove the earpiece speaker: step 38, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Remove the earpiece speaker: step 38, image 3 of 3
      • Insert the flat end of a spudger underneath the earpiece speaker to separate it from the frame.
      • Remove the earpiece speaker.
      Ask FixBot
    11. Motorola Moto E6 Plus Display Replacement, Remove the coaxial cable: step 39, image 1 of 3 Motorola Moto E6 Plus Display Replacement, Remove the coaxial cable: step 39, image 2 of 3 Motorola Moto E6 Plus Display Replacement, Remove the coaxial cable: step 39, image 3 of 3
      • Pull the coaxial cable out of its clips on the right side of the frame.
      Ask FixBot
    12. Motorola Moto E6 Plus Display Replacement: step 40, image 1 of 1
      • Only the display assembly remains.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto E6 Plus Answers community for help.
7 other people completed this guide.
Robert Boyd
33,762 Reputation
94 Guides authored
5 Guide Comments
After step 40, how do I remove the broken screen and replace the new one in the Display assembly frame?
My phone slightly differed in that I did not have to do step 10.
I got to step 20, and decided to stop as I didn't know how I was going to get the sticky label back on to the buttons later.
Peter Merchant - Reply Share
Oh, I have just read the introduction Note. I think my next steps are to get a new phone, and then when I have a few hours spare work through this fixit and then investigate how to remove the screen from the frame.
Cheers.
Using the tweezers, remove the paper backing from what was the battery place. Then using a hairdryer carefully, unstick and lift the ribbon cable running the length of that compartment. Lay the case down and heat up the case with the hairdryer. Then, inserting a small screwdriver through the hole in the back of the case, pry the screen from the case. Once again reverse the steps to insert the new screen.
Final comments. After finishing the job, I discovered that a bit of screening that went over the microphone (at the top)? was still attached to the old screen. I didn't refit it.
In retrospect, if I just had the screen as I did, and not already installed in the frame as you describe, It would not be necessary to remove all the electronics, just the covers to access the connectors. Thanks for this guide. it has been useful.
Does that mean you can just replace the screen not the display assembly?
Audrey Jacqueline - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 101
All Time: 6,485
