Motorola Moto E6 Plus Battery Replacement
  1. Motorola Moto E6 Plus Battery Replacement, Unclip the back cover: step 1, image 1 of 2 Motorola Moto E6 Plus Battery Replacement, Unclip the back cover: step 1, image 2 of 2
    • Use an opening tool or your fingernail to pry the back cover away from the frame using the notch at the bottom right corner.
  2. Motorola Moto E6 Plus Battery Replacement, Unclip the right edge: step 2, image 1 of 3 Motorola Moto E6 Plus Battery Replacement, Unclip the right edge: step 2, image 2 of 3 Motorola Moto E6 Plus Battery Replacement, Unclip the right edge: step 2, image 3 of 3
    • Use an opening tool or your fingernail to release the clips on the right edge by sliding up and around the top right corner.
  3. Motorola Moto E6 Plus Battery Replacement, Unclip the top edge: step 3, image 1 of 2 Motorola Moto E6 Plus Battery Replacement, Unclip the top edge: step 3, image 2 of 2
    • Continue to slide the opening tool or your fingernail across the top edge to release the clips securing the back cover to the frame.
  4. Motorola Moto E6 Plus Battery Replacement, Unclip the left edge: step 4, image 1 of 2 Motorola Moto E6 Plus Battery Replacement, Unclip the left edge: step 4, image 2 of 2
    • Continue to slide the opening tool or your fingernail down the left edge to release the clips.
  5. Motorola Moto E6 Plus Battery Replacement, Remove the back cover: step 5, image 1 of 3 Motorola Moto E6 Plus Battery Replacement, Remove the back cover: step 5, image 2 of 3 Motorola Moto E6 Plus Battery Replacement, Remove the back cover: step 5, image 3 of 3
    • Remove the back cover.
  6. Motorola Moto E6 Plus Battery Replacement, Remove the battery: step 6, image 1 of 3 Motorola Moto E6 Plus Battery Replacement, Remove the battery: step 6, image 2 of 3 Motorola Moto E6 Plus Battery Replacement, Remove the battery: step 6, image 3 of 3
    • Use a spudger or your fingernail to pry the battery up using the notch near the bottom right corner.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto E6 Plus Answers community for help.
5 other people completed this guide.
Robert Boyd
32,923 Reputation
94 Guides authored
2 Guide Comments
Well done, excellent step by step procedure. Very easy to follow, in fact the best I have ever come across.
Ken Mills - Reply Share
As I have previously stated the easiest and best step by step procedure I have ever come across. Well done author.
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 75
All Time: 5,611
