Motorola Moto E4 Vibrator Replacement
    1. Motorola Moto E4 Vibrator Replacement, Remove the rear cover: step 1, image 1 of 2 Motorola Moto E4 Vibrator Replacement, Remove the rear cover: step 1, image 2 of 2
      • Before removing the battery, power off your Moto E4.
      • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
      • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
      Ask FixBot
    1. Motorola Moto E4 Vibrator Replacement, Charging Port: step 2, image 1 of 1
      • Remove the six 4mm screws from the bottom plastic cover with a Phillips driver bit.
      Ask FixBot
    2. Motorola Moto E4 Vibrator Replacement: step 3, image 1 of 1
      • Gently pry the plastic cover from the phone using an iFixit opening tool.
      • Once loose, remove the plastic cover from the phone.
      Ask FixBot
    3. Motorola Moto E4 Vibrator Replacement: step 4, image 1 of 3 Motorola Moto E4 Vibrator Replacement: step 4, image 2 of 3 Motorola Moto E4 Vibrator Replacement: step 4, image 3 of 3
      • Detach the two ribbon cable connectors from the top of the board using an iFixit opening tool.
      • Unplug the antenna cable connector from the board using an iFixit opening tool.
      Ask FixBot
    4. Motorola Moto E4 Vibrator Replacement: step 5, image 1 of 3 Motorola Moto E4 Vibrator Replacement: step 5, image 2 of 3 Motorola Moto E4 Vibrator Replacement: step 5, image 3 of 3
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      Ask FixBot
    5. Motorola Moto E4 Vibrator Replacement: step 6, image 1 of 2 Motorola Moto E4 Vibrator Replacement: step 6, image 2 of 2
      • Remove the two 4mm silver screws holding down the charging port board with Phillips bit.
      Ask FixBot
    6. Motorola Moto E4 Vibrator Replacement: step 7, image 1 of 2 Motorola Moto E4 Vibrator Replacement: step 7, image 2 of 2
      • Place the iFixit opening tool underneath the board in between the micro USB port and the microphone.
      • Push forward and lift gently until the board lifts up.
      • Remove the charging port board from the device.
      Ask FixBot
    1. Motorola Moto E4 Vibrator Replacement, Vibrator: step 8, image 1 of 2 Motorola Moto E4 Vibrator Replacement, Vibrator: step 8, image 2 of 2
      • Gently pull the vibrator upwards to remove the vibrator wires from the silver clasp holding the wires to the board.
      • Pull directly upwards to remove the vibrator from its connector.
      Ask FixBot
Nate Tjepkema
1,296 Reputation
7 Guides authored
Cal Poly, Team S2-G4, White Winter 2019 Member of Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Members
83 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 873
