Motorola Moto E4 Plus Rear Camera Replacement
  1. Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: step 1, image 1 of 3 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: step 1, image 2 of 3 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Rear Camera Replacement: step 2, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement: step 2, image 2 of 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Rear Camera Replacement, Midframe: step 3, image 1 of 1
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Rear Camera Replacement: step 4, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement: step 4, image 2 of 2
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Rear Camera Replacement: step 5, image 1 of 3 Motorola Moto E4 Plus Rear Camera Replacement: step 5, image 2 of 3 Motorola Moto E4 Plus Rear Camera Replacement: step 5, image 3 of 3
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Rear Camera Replacement: step 6, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement: step 6, image 2 of 2
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Rear Camera Replacement: step 7, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement: step 7, image 2 of 2
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Rear Camera Replacement: step 8, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement: step 8, image 2 of 2
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: step 9, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: step 9, image 2 of 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: step 10, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: step 10, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
    • Fold the copper tape out of the way.
  11. Motorola Moto E4 Plus Rear Camera Replacement: step 11, image 1 of 2 Motorola Moto E4 Plus Rear Camera Replacement: step 11, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
  12. Motorola Moto E4 Plus Rear Camera Replacement: step 12, image 1 of 1
    • Carefully remove the rear camera with a pair of tweezers.
If possible, turn on your phone and test your repair before reassembly.
5 other people completed this guide.
Dominik Schnabelrauch
258,018 Reputation
682 Guides authored
1 Guide Comment
I want Moto e 4 + camera
Mubbu N - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 46
All Time: 1,844
