Motorola Moto E4 Plus Front-Facing Camera Replacement
    1. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the back cover: step 1, image 1 of 3 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the back cover: step 1, image 2 of 3 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the back cover: step 1, image 3 of 3
      • Power off your phone before beginning disassembly.
      • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
      • Twist the spudger to start releasing the back cover from the phone.
      • Slide the spudger along the bottom edge to separate the back cover from the phone.
      Ask FixBot
    2. Motorola Moto E4 Plus Front-Facing Camera Replacement: step 2, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement: step 2, image 2 of 2
      • Lift the phone unit out of the back cover.
      Ask FixBot
    1. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the midframe screws: step 3, image 1 of 1
      • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
      Ask FixBot
    2. Motorola Moto E4 Plus Front-Facing Camera Replacement, Release the midframe clips: step 4, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Release the midframe clips: step 4, image 2 of 2
      • The plastic midframe is still held in place with clips.
      • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
      • Twist the spudger to release the plastic clip.
      • Repeat the process for the clip near the top right corner of the phone.
      Ask FixBot
    3. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the midframe: step 5, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the midframe: step 5, image 2 of 2
      • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
      • Remove the plastic midframe.
      • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
      Ask FixBot
    1. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the battery: step 6, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the battery: step 6, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
      Ask FixBot
    1. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the display cable: step 7, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the display cable: step 7, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket, near the bottom left corner of the motherboard.
      Ask FixBot
    2. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the antenna cable: step 8, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the antenna cable: step 8, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the antenna cable from its motherboard socket.
      Ask FixBot
    3. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the interconnect cable: step 9, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the interconnect cable: step 9, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket.
      Ask FixBot
    4. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the motherboard screws: step 10, image 1 of 1
      • Remove the two black 3.2 mm long T3 screws securing the motherboard.
      Ask FixBot
    5. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the motherboard: step 11, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the motherboard: step 11, image 2 of 2
      • Grasp the motherboard by the top corners and lift it out of the phone.
      • Remove the motherboard.
      Ask FixBot
    1. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the front-facing camera: step 12, image 1 of 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the front-facing camera: step 12, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the front-facing camera from its motherboard socket.
      Ask FixBot
    2. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the front-facing camera: step 13, image 1 of 1
      • Flip the motherboard over.
      • Remove the front-facing camera.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
Arthur Shi
346,947 Reputation
923 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,581 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 565
