Motorola Moto E4 Front Facing Camera Replacement
    1. Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: step 1, image 1 of 2 Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: step 1, image 2 of 2
      • Before removing the battery, power off your Moto E4.
      • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
      • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
      Ask FixBot
    1. Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: step 2, image 1 of 2 Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: step 2, image 2 of 2
      • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
      Ask FixBot
    2. Motorola Moto E4 Front Facing Camera Replacement: step 3, image 1 of 2 Motorola Moto E4 Front Facing Camera Replacement: step 3, image 2 of 2
      • Gently pry up the plastic cover from the gap between it and the phone edge.
      • Start on the right side as indicated by the first picture.
      • Continue prying around the rest of the cover in a counter clockwise path.
      • Once loose, remove the plastic cover from the phone.
      Ask FixBot
    1. Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: step 4, image 1 of 2 Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: step 4, image 2 of 2
      • Detach the front facing cable ribbon connector using an iFixit opening tool and lift the camera out of position.
      • To completely remove the front facing camera from the phone, the copper colored adhesive must be torn. The camera will still with the adhesive removed, but there may be unknown side effects.
      Ask FixBot
2 other people completed this guide.
Nate Tjepkema
1,296 Reputation
7 Guides authored
Cal Poly, Team S2-G4, White Winter 2019 Member of Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Members
83 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 849
