Motorola Moto 360 2nd Gen LCD Display Replacement
    1. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the watch band: step 1, image 1 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the watch band: step 1, image 2 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the watch band: step 1, image 3 of 3
      • Use your finger or the tip of a spudger to compress the pin securing the watch band.
      • With the pin compressed, remove the watch band.
      Ask FixBot
    2. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the trim ring: step 2, image 1 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the trim ring: step 2, image 2 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the trim ring: step 2, image 3 of 3
      • Insert an opening tool to into the small notch next to the microphone hole.
      • Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
      • If the trim ring does not readily separate from the watch, heat it with an iOpener or hair dryer to soften the adhesive.
      • Remove the trim ring.
      Ask FixBot
    3. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button trim: step 3, image 1 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button trim: step 3, image 2 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button trim: step 3, image 3 of 3
      • Use an opening tool to slowly pry the button trim ring straight up.
      • If you bend or rotate the trim ring while removing it, you may damage the small pins that secure it.
      Ask FixBot
    4. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button: step 4, image 1 of 2 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use a small pin spanner to unscrew the button.
      • If you don't have access to the proper spanner, you can use a pair of tweezers, a very small screwdriver, or a paperclip to unscrew the button assembly. Insert your chosen tool into one of the grooves around the button and push sideways.
      • There is blue thread locker on these threads, so light heat on the button may help to soften the thread locker.
      • Remove the button.
      • There is a small red o-ring that may fall off the button threads when the button is removed. Make sure not to lose the o-ring.
      Ask FixBot
    5. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the inner assembly: step 5, image 1 of 2 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the inner assembly: step 5, image 2 of 2
      • While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
      Ask FixBot
    6. Motorola Moto 360 2nd Gen LCD Display Replacement: step 6, image 1 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement: step 6, image 2 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement: step 6, image 3 of 3
      • Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
      • It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
      Ask FixBot
    7. Motorola Moto 360 2nd Gen LCD Display Replacement, Open the inner assembly: step 7, image 1 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Open the inner assembly: step 7, image 2 of 3 Motorola Moto 360 2nd Gen LCD Display Replacement, Open the inner assembly: step 7, image 3 of 3
      • Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
      • Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
      Ask FixBot
    8. Motorola Moto 360 2nd Gen LCD Display Replacement: step 8, image 1 of 1
      • Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
      Ask FixBot
    9. Motorola Moto 360 2nd Gen LCD Display Replacement: step 9, image 1 of 2 Motorola Moto 360 2nd Gen LCD Display Replacement: step 9, image 2 of 2
      • Use a spudger to lift the locking flap on the display ZIF connector.
      Ask FixBot
    10. Motorola Moto 360 2nd Gen LCD Display Replacement: step 10, image 1 of 2 Motorola Moto 360 2nd Gen LCD Display Replacement: step 10, image 2 of 2
      • Lift the display cable straight out of its connector on the motherboard.
      Ask FixBot
    1. Motorola Moto 360 2nd Gen LCD Display Replacement, Removing LCD: step 11, image 1 of 1
      • Place the screen frame on a solid surface on its back, put even pressure down across the screen to put it out of the back of the frame, warming it will help loosen the adhesive.
      Ask FixBot
8 other people completed this guide.
Ivana Lum Wai
281 Reputation
1 Guide authored
USF Tampa, Team S6-G1, Remmell Fall 2017 Member of USF Tampa, Team S6-G1, Remmell Fall 2017
USFT-REMMELL-F17S6G1
4 Members
32 Guides authored
4 Guide Comments
Where can I buy the screen for the 2-nd generation Moto360 watch ?
Kevin - Reply Share
Its far easier to remove watch from body by unscrewing the crown, remove the bottom ring then heat the bezel a little so that you can turn the bezel about 10mm counter clockwise with a razor blade edge, then push the whole body of the watch through the metal casing and it should come out easily through the top of the watch in one piece making it easier to access the pcb without damaging anything
Bernard McGrath - Reply Share
There is only one correct way to disassemble the watch. That is to unscrew the crown as mentioned in previous comment and another guide for 360 Gen 2.
This guide here should be either revised or taken down.
It leads to broken watch if you tried to follow. I was lucky to step out from step 5 and followed the other guide instead…
vincent0wang - Reply Share
That last step will destroy the screen btw. Sticking a knife down the side to pry it out will just rip the backlight off the lcd. You put even pressure on the glass on the front to pop it out of the back, might take a while as it's stuck in. warming it will help.
Arkz - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 8,675
