Introduction
Improve keyboard function by replacing the functional keypad for your Motorola MOTO phone.
Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
Slide the opening tool around the phone clockwise until you reach the audio port.
Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
Lift the plastic cover of the keypad from the top of the main logic board and peel it off.
