Motorola MC5590 Speaker Replacement
  1. Motorola MC5590 Speaker Replacement, Battery: step 1, image 1 of 1
    • Push in the battery release button.
  2. Motorola MC5590 Speaker Replacement: step 2, image 1 of 1
    • Pull out battery.
  3. Motorola MC5590 Speaker Replacement, Keyboard: step 3, image 1 of 2 Motorola MC5590 Speaker Replacement, Keyboard: step 3, image 2 of 2
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Speaker Replacement: step 4, image 1 of 3 Motorola MC5590 Speaker Replacement: step 4, image 2 of 3 Motorola MC5590 Speaker Replacement: step 4, image 3 of 3
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Speaker Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Speaker Replacement: step 6, image 1 of 2 Motorola MC5590 Speaker Replacement: step 6, image 2 of 2
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Speaker Replacement: step 7, image 1 of 1
    • Remove the keyboard cover.
  8. Motorola MC5590 Speaker Replacement: step 8, image 1 of 3 Motorola MC5590 Speaker Replacement: step 8, image 2 of 3 Motorola MC5590 Speaker Replacement: step 8, image 3 of 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Speaker Replacement: step 9, image 1 of 2 Motorola MC5590 Speaker Replacement: step 9, image 2 of 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Speaker Replacement, Speaker: step 10, image 1 of 2 Motorola MC5590 Speaker Replacement, Speaker: step 10, image 2 of 2
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Speaker Replacement: step 11, image 1 of 2 Motorola MC5590 Speaker Replacement: step 11, image 2 of 2
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Speaker Replacement: step 12, image 1 of 2 Motorola MC5590 Speaker Replacement: step 12, image 2 of 2
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Speaker Replacement: step 13, image 1 of 2 Motorola MC5590 Speaker Replacement: step 13, image 2 of 2
    • Disconnect the speaker from the motherboard.
Tyler Jean
555 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Cagle Spring 2018 Member of USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 37
All Time: 346
