Motorola MC5590 LCD Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
55
All Time:
1,202
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help the user to replace the LCD screen on the MC55 series device. The MC55 series is intended for industrial and commercial use and the screen is thus likely to be broken. Here, the user will learn how to break down the device and replace a broken or faulty LCD screen.
Tools
    1. Motorola MC5590 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Push in the battery release button.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 2, image 1 of 1
      • Pull out battery.
      Ask FixBot
    1. Motorola MC5590 LCD Screen Replacement, Keyboard: step 3, image 1 of 2 Motorola MC5590 LCD Screen Replacement, Keyboard: step 3, image 2 of 2
      • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 4, image 1 of 3 Motorola MC5590 LCD Screen Replacement: step 4, image 2 of 3 Motorola MC5590 LCD Screen Replacement: step 4, image 3 of 3
      • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
      Ask FixBot
    3. Motorola MC5590 LCD Screen Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
      Ask FixBot
    4. Motorola MC5590 LCD Screen Replacement: step 6, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 6, image 2 of 2
      • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
      Ask FixBot
    5. Motorola MC5590 LCD Screen Replacement: step 7, image 1 of 1
      • Remove the keyboard cover.
      Ask FixBot
    6. Motorola MC5590 LCD Screen Replacement: step 8, image 1 of 3 Motorola MC5590 LCD Screen Replacement: step 8, image 2 of 3 Motorola MC5590 LCD Screen Replacement: step 8, image 3 of 3
      • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Pull the ribbon cable out of the socket.
      Ask FixBot
    7. Motorola MC5590 LCD Screen Replacement: step 9, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 9, image 2 of 2
      • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
      • Remove the keyboard from the device.
      Ask FixBot
    1. Motorola MC5590 LCD Screen Replacement, Speaker: step 10, image 1 of 2 Motorola MC5590 LCD Screen Replacement, Speaker: step 10, image 2 of 2
      • Pull the black rubber tabs up gently and remove them.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 11, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 11, image 2 of 2
      • Using your finger, or spudger, push the motherboard out from the bottom.
      Ask FixBot
    3. Motorola MC5590 LCD Screen Replacement: step 12, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 12, image 2 of 2
      • Remove the three Phillips #00 screws from the motherboard:
      • Two 3mm screws.
      • One 1mm screw.
      Ask FixBot
    4. Motorola MC5590 LCD Screen Replacement: step 13, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 13, image 2 of 2
      • Disconnect the speaker from the motherboard.
      Ask FixBot
    1. Motorola MC5590 LCD Screen Replacement, LCD Screen: step 14, image 1 of 3 Motorola MC5590 LCD Screen Replacement, LCD Screen: step 14, image 2 of 3 Motorola MC5590 LCD Screen Replacement, LCD Screen: step 14, image 3 of 3
      • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
      • Remove the antenna.
      • Remove the flex cable cover.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 15, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 15, image 2 of 2
      • Remove the five 3mm Phillips #00 screws from the motherboard.
      Ask FixBot
    3. Motorola MC5590 LCD Screen Replacement: step 16, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 16, image 2 of 2
      • Remove the scanner ribbon cable by pulling straight up and out.
      Ask FixBot
    4. Motorola MC5590 LCD Screen Replacement: step 17, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 17, image 2 of 2
      • Flip open the motherboard and the LCD screen.
      • Open the LCD connector and remove the cable.
      • Pull the LCD Screen and its metal bracket apart.
      Ask FixBot
Tyler Jean
555 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Cagle Spring 2018 Member of USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 55
All Time: 1,202
