Motorola MC5590 Charging Port Replacement
  1. Motorola MC5590 Charging Port Replacement, Battery: step 1, image 1 of 1
    • Push in the battery release button.
    Ask FixBot
  2. Motorola MC5590 Charging Port Replacement: step 2, image 1 of 1
    • Pull out battery.
    Ask FixBot
  3. Motorola MC5590 Charging Port Replacement, Keyboard: step 3, image 1 of 2 Motorola MC5590 Charging Port Replacement, Keyboard: step 3, image 2 of 2
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
    Ask FixBot
  4. Motorola MC5590 Charging Port Replacement: step 4, image 1 of 3 Motorola MC5590 Charging Port Replacement: step 4, image 2 of 3 Motorola MC5590 Charging Port Replacement: step 4, image 3 of 3
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
    Ask FixBot
  5. Motorola MC5590 Charging Port Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
    Ask FixBot
  6. Motorola MC5590 Charging Port Replacement: step 6, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 6, image 2 of 2
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
    Ask FixBot
  7. Motorola MC5590 Charging Port Replacement: step 7, image 1 of 1
    • Remove the keyboard cover.
    Ask FixBot
  8. Motorola MC5590 Charging Port Replacement: step 8, image 1 of 3 Motorola MC5590 Charging Port Replacement: step 8, image 2 of 3 Motorola MC5590 Charging Port Replacement: step 8, image 3 of 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    Ask FixBot
  9. Motorola MC5590 Charging Port Replacement: step 9, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 9, image 2 of 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
    Ask FixBot
  10. Motorola MC5590 Charging Port Replacement, Speaker: step 10, image 1 of 2 Motorola MC5590 Charging Port Replacement, Speaker: step 10, image 2 of 2
    • Pull the black rubber tabs up gently and remove them.
    Ask FixBot
  11. Motorola MC5590 Charging Port Replacement: step 11, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 11, image 2 of 2
    • Using your finger, or spudger, push the motherboard out from the bottom.
    Ask FixBot
  12. Motorola MC5590 Charging Port Replacement: step 12, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 12, image 2 of 2
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
    Ask FixBot
  13. Motorola MC5590 Charging Port Replacement: step 13, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 13, image 2 of 2
    • Disconnect the speaker from the motherboard.
    Ask FixBot
  14. Motorola MC5590 Charging Port Replacement, LCD Screen: step 14, image 1 of 3 Motorola MC5590 Charging Port Replacement, LCD Screen: step 14, image 2 of 3 Motorola MC5590 Charging Port Replacement, LCD Screen: step 14, image 3 of 3
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
    Ask FixBot
  15. Motorola MC5590 Charging Port Replacement: step 15, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 15, image 2 of 2
    • Remove the five 3mm Phillips #00 screws from the motherboard.
    Ask FixBot
  16. Motorola MC5590 Charging Port Replacement: step 16, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 16, image 2 of 2
    • Remove the scanner ribbon cable by pulling straight up and out.
    Ask FixBot
  17. Motorola MC5590 Charging Port Replacement: step 17, image 1 of 2 Motorola MC5590 Charging Port Replacement: step 17, image 2 of 2
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
    Ask FixBot
  18. Motorola MC5590 Charging Port Replacement, Internal Antenna: step 18, image 1 of 2 Motorola MC5590 Charging Port Replacement, Internal Antenna: step 18, image 2 of 2
    • Remove the antenna connector (red box).
    • This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
    Ask FixBot
  19. Motorola MC5590 Charging Port Replacement, Charging Port: step 19, image 1 of 1
    • Remove the 2 screws (3 mm long) at the bottom of the motherboard using a PH00-bit screwdriver.
    • Disconnect the charging port from the rest of the device.
    Ask FixBot
Tyler Jean
555 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Cagle Spring 2018 Member of USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 24
All Time: 561
