Motorola MBP667CONNECT Circuit Board Replacement
  1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: step 1, image 1 of 3 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: step 1, image 2 of 3 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: step 1, image 3 of 3
    • Remove the two 5 mm Phillips #1 screws on the back of the camera.
    • Use a nylon spudger to remove the casing.
    Ask FixBot
  2. Motorola MBP667CONNECT Circuit Board Replacement: step 2, image 1 of 3 Motorola MBP667CONNECT Circuit Board Replacement: step 2, image 2 of 3 Motorola MBP667CONNECT Circuit Board Replacement: step 2, image 3 of 3
    • Remove the brackets by the speaker on the front side of the camera using the metal spudger.
    • Continue to use the metal spudger to carefully disconnect remaining brackets from casing.
    • Remove the two 5mm Phillips #1 screws on the backside of the camera.
    Ask FixBot
  3. Motorola MBP667CONNECT Circuit Board Replacement: step 3, image 1 of 3 Motorola MBP667CONNECT Circuit Board Replacement: step 3, image 2 of 3 Motorola MBP667CONNECT Circuit Board Replacement: step 3, image 3 of 3
    • Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
    • Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
    • Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
    Ask FixBot
  4. Motorola MBP667CONNECT Circuit Board Replacement: step 4, image 1 of 2 Motorola MBP667CONNECT Circuit Board Replacement: step 4, image 2 of 2
    • You will now be able to carefully pull the receiver wire through the gap in the casing.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 652
