Motorola MBP667CONNECT Camera Stand Replacement
    1. Motorola MBP667CONNECT Camera Stand Replacement, Camera Stand: step 1, image 1 of 2 Motorola MBP667CONNECT Camera Stand Replacement, Camera Stand: step 1, image 2 of 2
      • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
      Ask FixBot
    2. Motorola MBP667CONNECT Camera Stand Replacement: step 2, image 1 of 1
      • Use a nylon spudger to remove the casing.
      Ask FixBot
    3. Motorola MBP667CONNECT Camera Stand Replacement: step 3, image 1 of 1
      • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
      Ask FixBot
    4. Motorola MBP667CONNECT Camera Stand Replacement: step 4, image 1 of 2 Motorola MBP667CONNECT Camera Stand Replacement: step 4, image 2 of 2
      • Remove the black circular plastic part.
      Ask FixBot
    5. Motorola MBP667CONNECT Camera Stand Replacement: step 5, image 1 of 1
      • Remove the white plastic wire housing beneath the black plastic.
      Ask FixBot
    6. Motorola MBP667CONNECT Camera Stand Replacement: step 6, image 1 of 2 Motorola MBP667CONNECT Camera Stand Replacement: step 6, image 2 of 2
      • Now, remove the bottom of the stand by pulling it from the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 827
