Motorola Lapdock 100 Trackpad Replacement
    1. Motorola Lapdock 100 Trackpad Replacement, Lower Case: step 1, image 1 of 2 Motorola Lapdock 100 Trackpad Replacement, Lower Case: step 1, image 2 of 2
      • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
      • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
      Ask FixBot
    2. Motorola Lapdock 100 Trackpad Replacement: step 2, image 1 of 1
      • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
      Ask FixBot
    3. Motorola Lapdock 100 Trackpad Replacement: step 3, image 1 of 1
      • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
      Ask FixBot
    4. Motorola Lapdock 100 Trackpad Replacement: step 4, image 1 of 2 Motorola Lapdock 100 Trackpad Replacement: step 4, image 2 of 2
      • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
      Ask FixBot
    5. Motorola Lapdock 100 Trackpad Replacement: step 5, image 1 of 2 Motorola Lapdock 100 Trackpad Replacement: step 5, image 2 of 2
      • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
      Ask FixBot
    6. Motorola Lapdock 100 Trackpad Replacement: step 6, image 1 of 3 Motorola Lapdock 100 Trackpad Replacement: step 6, image 2 of 3 Motorola Lapdock 100 Trackpad Replacement: step 6, image 3 of 3
      • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
      Ask FixBot
    7. Motorola Lapdock 100 Trackpad Replacement: step 7, image 1 of 2 Motorola Lapdock 100 Trackpad Replacement: step 7, image 2 of 2
      • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
      Ask FixBot
    1. Motorola Lapdock 100 Trackpad Replacement, Trackpad: step 8, image 1 of 2 Motorola Lapdock 100 Trackpad Replacement, Trackpad: step 8, image 2 of 2
      • Remove the five 1.2mm long screws with the PH0 screwdriver from track pad reinforcement frame.
      Ask FixBot
    2. Motorola Lapdock 100 Trackpad Replacement: step 9, image 1 of 3 Motorola Lapdock 100 Trackpad Replacement: step 9, image 2 of 3 Motorola Lapdock 100 Trackpad Replacement: step 9, image 3 of 3
      • Unplug track pad from the ribbon cable that is attaching it to the motherboard then use a plastic prying tool to take out the track-pad.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 25
Past 30 Days: 39
All Time: 684
