Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Use a heat gun or hair dryer to soften the adhesive on the rear cover
Open case from the on button side face down. You will need a T4 bit driver.
Pry off the black and white wires with a pry tool. Remove Philips screw.
Clean all the gasket off.
There is only room for one layer, for a smooth cover fit.
Remove finger print reader cable to install new cover gasket. surface must be clean so the cover sits tight with no gaps.
Install FPR cable.
Install the keep.
Put tape on the cover to align the edges.
Tape helps align cover for a smooth install.
Press the cover on to seal.
4 other people completed this guide.
