Up to 20% off select tools
Motorola G30 screen replacement
Views: 4.4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
57
Past 30 Days:
248
All Time:
4,379
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 hours
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Guide to replace a broken screen on Moto G30 phones. On this model, the label on the back says "Type: MC391".
    1. Motorola G30 screen replacement, Remove SIM card: step 1, image 1 of 1
      • Remove the SIM card tray with a pin or a small pointy object
      Ask FixBot
    2. Motorola G30 screen replacement, Unclip the back cover: step 2, image 1 of 1
      • Unclip the plastic back cover using any tool you like (mediators, sprudgers, Jimmy...)
      • Be careful not to lift the cover too far from the phone, it has to be lifted cautiously because a cable is attached to it
      Ask FixBot
    3. Motorola G30 screen replacement, Unscrew the optical cover part: step 3, image 1 of 2 Motorola G30 screen replacement, Unscrew the optical cover part: step 3, image 2 of 2
      • Slighly move the back cover in order to unscrew the plastic piece behind it
      • Remove the 9 small Philips-head screws inside
      • You will also have to remove small black adhesive pieces to be able to remove the part completely
      Ask FixBot
    4. Motorola G30 screen replacement, Free the back panel: step 4, image 1 of 1
      • Once the black plastic cover piece is removed, unplug the cable holding the back panel
      • Once this flex cable unplugged, lift the back panel completely
      Ask FixBot
    5. Motorola G30 screen replacement, Unplug battery and screen: step 5, image 1 of 1
      • Unplug both battery and display connectors
      • Battery on the right
      • Display in the middle
      • You can use the opening tool as lever.
      Ask FixBot
    6. Motorola G30 screen replacement, Unglue the battery: step 6, image 1 of 1
      • Very carefully unglue the battery
      • Adhesive is quite strong here, and the battery is not very rigid, so this is a complicated operation. It would be dangerous to head the battery cell, be patient and careful.
      Ask FixBot
    7. Motorola G30 screen replacement, Disconnect the bottom PCB: step 7, image 1 of 1
      • Unscrew the cover at the bottom of the phone
      • 7 small Philips head screws to remove
      • A little black adhesive to peel off around the edges
      • Unplug the connector
      Ask FixBot
    8. Motorola G30 screen replacement, Unglue display cable: step 8, image 1 of 1
      • Detach the display flex cable from the back of the chassis
      Ask FixBot
    9. Motorola G30 screen replacement, Remove the screen: step 9, image 1 of 3 Motorola G30 screen replacement, Remove the screen: step 9, image 2 of 3 Motorola G30 screen replacement, Remove the screen: step 9, image 3 of 3
      • Steps 9 and 10 are only useful if you order the display without its frame. Move on to step 11 if you intend to order the display with its frame
      • Heat up to help unglue the screen
      • Battery has to be removed first, heating batteries is dangerous
      • Unglue the display from the chassis
      • I could not properly unglue with a cutter blade on the side. My technique is simpler and more brutal: I pushed the display away from the connector hole, with a rigid tool.
      Ask FixBot
    10. Motorola G30 screen replacement, Clean up the frame: step 10, image 1 of 1
      • Remove the glass shards still glued around the frame
      • Put some gloves on, because glass shards are dangerous!
      Ask FixBot
    11. Motorola G30 screen replacement, Optional: test phone: step 11, image 1 of 2 Motorola G30 screen replacement, Optional: test phone: step 11, image 2 of 2
      • Replug the battery pack
      • Test the battery voltage on the test point to the left of the connector (the ground is everywhere on the metal chassis): it must be between 3.6 and 4.2 V
      • You can also test the motherboard with a Linux-based computer
      • Unglue the screen-USB-motherboard flex cable from your broken screen, and replug the bottom USB board with the top motherboard
      • Turn on phone with Power On + Up buttons
      • Plug it to the computer with an USB-C cable
      • Type "lsusb" in a shell
      • If you can read something like "22b8:XXXX Motorola PCS moto g(30)", congratulations: your motherboard still lives
      Ask FixBot
    12. Motorola G30 screen replacement, Order replacement screen: step 12, image 1 of 2 Motorola G30 screen replacement, Order replacement screen: step 12, image 2 of 2
      • Once your phone has been successfully torn down and tested, it is time to order the replacement screen
      • The part will cost you around 15-20€. You can find it here for instance
      • Two choices: ordering the display pre-assembled on a new frame, or ordering it without
      • I recommend pre-assembled display, it will be more sturdy and less subject to breaking
      • While waiting for your order, don’t forget to store your parts and small screw properly
      Ask FixBot
    13. Motorola G30 screen replacement, Screen with frame: step 13, image 1 of 1
      • If you ordered the display pre-assembled on a frame, you will have to move all the components from the old chassis to the new one
      Ask FixBot
    14. Motorola G30 screen replacement, Move the buttons: step 14, image 1 of 3 Motorola G30 screen replacement, Move the buttons: step 14, image 2 of 3 Motorola G30 screen replacement, Move the buttons: step 14, image 3 of 3
      • You will find the small button panel on the chassis side, unglue it carefully
      • Start by ungluing the black tape covering it
      • Unplug the button connector from the main PCB
      • Unglue the button flex board carefully
      • Glue it on the new chassis
      Ask FixBot
    15. Motorola G30 screen replacement, Unscrew PCB from frame: step 15, image 1 of 2 Motorola G30 screen replacement, Unscrew PCB from frame: step 15, image 2 of 2
      • Unscrew both PCB
      • The top one is held by 2 screws
      • The bottom one is help by one screw
      Ask FixBot
    16. Motorola G30 screen replacement, Move top items: step 16, image 1 of 3 Motorola G30 screen replacement, Move top items: step 16, image 2 of 3 Motorola G30 screen replacement, Move top items: step 16, image 3 of 3
      • Slide the top PCB out of the chassis
      • Under it, there is a small undefined module, and an opaque sticker
      • Get the module out of its casing
      • Unglue the sticker under it
      • Replace both module and sticker on the other side
      Ask FixBot
    17. Motorola G30 screen replacement, Unglue the haptic module: step 17, image 1 of 2 Motorola G30 screen replacement, Unglue the haptic module: step 17, image 2 of 2
      • Remove the bottom PCB
      • The haptic module is under it, unglue it carefully
      • Start by the connector side
      • Once the connector side is lifted, it is easier to get to the rest of the module and unglue it
      Ask FixBot
    18. Motorola G30 screen replacement, Salvage the stickers or replace them: step 18, image 1 of 1
      • Try to salvage the stickers and glue them back to the new frame
      • You can also use new stickers
      • The pink sticker is a very thin thermal pad, you can replace it by thermal paste
      • The orange sticker is a tape copper foil
      • I don’t know how to replace the metallic grey thing, it is probably use for a better RF shielding
      Ask FixBot
    19. Motorola G30 screen replacement, Insert the top PCB: step 19, image 1 of 2 Motorola G30 screen replacement, Insert the top PCB: step 19, image 2 of 2
      • Insert the top PCB into the new frame
      • Don’t forget to move the button PCB small connector out of the way, it could get stuck under the board
      Ask FixBot
    20. Motorola G30 screen replacement, Plug the elements back: step 20, image 1 of 1
      • Plug the elements back
      • Top and bottom screen module connectors
      • Right-side antenna cable
      • Small button PCB connector
      • Screw the boards back in place
      Ask FixBot
    21. Motorola G30 screen replacement, Rescrew covers: step 21, image 1 of 2 Motorola G30 screen replacement, Rescrew covers: step 21, image 2 of 2
      • Replug the back cover connector
      • A step you don’t see on the pictures because I forgot
      • Rescrew the two PCB covers
      Ask FixBot
    22. Motorola G30 screen replacement, Clip the cover back into place: step 22, image 1 of 1
      • Clip the cover back in place
      • Insert the SIM card holder
      Ask FixBot
Unfortunately, my phone is bricked, so I could never turn it on and test the new screen. I hope you will get more luck than me!
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Eve Redero
3,414 Reputation
11 Guides authored
1 Guide Comment
Deze handleiding werkt ook voor de Moto G30 met typenummer MC390. Op een enkel punt ziet het frame van het nieuwe scherm er net iets anders uit, maar alles zit op dezelfde plek. De ongedefinieerde module uit stap 16 is de speaker. Na vervanging werkte het toestel weer naar behoren.
Realbspider - Reply Share
Past 24 Hours: 11
Past 7 Days: 57
Past 30 Days: 248
All Time: 4,379
