Motorola Entice w766 Motherboard Replacement
  1. Motorola Entice w766 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Slide the tab off the back of the device.
  2. Motorola Entice w766 Motherboard Replacement: step 2, image 1 of 1
    • Use the tab located at the top of the battery to release the battery.
  3. Motorola Entice w766 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Motorola Entice w766 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Motorola Entice w766 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • The six screws need to be taken out with any conventional screw driver tool.
    • You will have to unscrew the six 5.31 mm Star Head #5 screws with the appropriate six star bit.
    • There should be six screws removed from the casing after completion.
  4. Motorola Entice w766 Motherboard Replacement: step 4, image 1 of 3 Motorola Entice w766 Motherboard Replacement: step 4, image 2 of 3 Motorola Entice w766 Motherboard Replacement: step 4, image 3 of 3
    • First you will need to locate the lip on the left side of the device.
    • Next you will insert the black spudger firmly into side opening to loosen the casing.
    • Using the blue pry tool gently remove the black and silver casing.
    • The motherboard should then be exposed after removal.
  5. Motorola Entice w766 Motherboard Replacement: step 5, image 1 of 3 Motorola Entice w766 Motherboard Replacement: step 5, image 2 of 3 Motorola Entice w766 Motherboard Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the flex cable with a pair of tweezers.
    • Be gentle with the flex cable as not to break the connecting wire.
    • Now use a spudger or pry tool to place firmly under the motherboard.
    • After creating clearance with the spudging device grab and remove the motherboard with a clamping tool or hand.
    • Look at the motherboard for scorches or loose pieces which could indicate damage.
    • Refer to the troubleshooting page for further advice to replace the motherboard.
Aalan Miranda
210 Reputation
2 Guides authored
IUPUI-Harley-F16S2G4 Member of IUPUI-Harley-F16S2G4
Community
4 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 34
All Time: 457
