Motorola Edge Plus 2022 I/O Board
  1. Motorola Edge Plus 2022 I/O Board, Battery: step 1, image 1 of 1
    • Press and hold the power button for 7 seconds.
    • You will know the phone is fully powered off when the Motorola logo appears on the screen.
  2. Motorola Edge Plus 2022 I/O Board: step 2, image 1 of 1
    • Insert a paperclip or SIM card ejector into the small hole located at the bottom of phone.
    • Gently push to release and remove the SIM card.
  3. Motorola Edge Plus 2022 I/O Board: step 3, image 1 of 3 Motorola Edge Plus 2022 I/O Board: step 3, image 2 of 3 Motorola Edge Plus 2022 I/O Board: step 3, image 3 of 3
    • Use an iOpener, heat gun, or hairdryer to gently heat the perimeter of the phone.
    • Insert and slide the iFixit opening pick around heated edges to sever the adhesive securing the rear cover.
  4. Motorola Edge Plus 2022 I/O Board: step 4, image 1 of 3 Motorola Edge Plus 2022 I/O Board: step 4, image 2 of 3 Motorola Edge Plus 2022 I/O Board: step 4, image 3 of 3
    • Gently remove the back cover using the suction handle or your bare hands.
  5. Motorola Edge Plus 2022 I/O Board: step 5, image 1 of 2 Motorola Edge Plus 2022 I/O Board: step 5, image 2 of 2
    • While applying light pressure, remove the camera bezel cover by sliding the jimmy along the edges.
  6. Motorola Edge Plus 2022 I/O Board: step 6, image 1 of 2 Motorola Edge Plus 2022 I/O Board: step 6, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the twelve 1.5 mm black screws.
    • In case a screw gets lost, the exact specifications for all screws in this guide are OEM MOTOROLA EDGE+ PLUS 5G UW.
  7. Motorola Edge Plus 2022 I/O Board: step 7, image 1 of 3 Motorola Edge Plus 2022 I/O Board: step 7, image 2 of 3 Motorola Edge Plus 2022 I/O Board: step 7, image 3 of 3
    • Remove the logic board by lifting gently with the flat end of the spudger.
  8. Motorola Edge Plus 2022 I/O Board: step 8, image 1 of 3 Motorola Edge Plus 2022 I/O Board: step 8, image 2 of 3 Motorola Edge Plus 2022 I/O Board: step 8, image 3 of 3
    • Use the flat end of a spudger to to pry up and disconnect the two press connectors on either side of the battery.
    • Located in the bottom left corner of the battery, remove the tape (black in the image) with a spudger.
  9. Motorola Edge Plus 2022 I/O Board: step 9, image 1 of 3 Motorola Edge Plus 2022 I/O Board: step 9, image 2 of 3 Motorola Edge Plus 2022 I/O Board: step 9, image 3 of 3
    • Gently lift the battery up using the black spudger and remove.
    • Applying too much force when removing the battery may damage it. Take care not to bend, warp, or puncture the battery.
    • Apply a few drops of isopropyl alcohol if the battery is tightly adhered.
  10. Motorola Edge Plus 2022 I/O Board, Daughterboard: step 10, image 1 of 3 Motorola Edge Plus 2022 I/O Board, Daughterboard: step 10, image 2 of 3 Motorola Edge Plus 2022 I/O Board, Daughterboard: step 10, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws securing the motherboard.
  11. Motorola Edge Plus 2022 I/O Board: step 11, image 1 of 2 Motorola Edge Plus 2022 I/O Board: step 11, image 2 of 2
    • Gently lift and remove the daughterboard cover.
  12. Motorola Edge Plus 2022 I/O Board: step 12, image 1 of 2 Motorola Edge Plus 2022 I/O Board: step 12, image 2 of 2
    • Insert the flat end of the spudger under each of the three press connectors and gently pry them up to disconnect them.
  13. Motorola Edge Plus 2022 I/O Board: step 13, image 1 of 3 Motorola Edge Plus 2022 I/O Board: step 13, image 2 of 3 Motorola Edge Plus 2022 I/O Board: step 13, image 3 of 3
    • Disconnect the three coaxial connectors (black, white, and blue) with tweezers by pulling them straight up.
    • Use a Phillips #00 screwdriver to remove the two 1.5 mm silver screws securing the daughterboard and charging port.
  14. Motorola Edge Plus 2022 I/O Board: step 14, image 1 of 1
    • Insert the flat end of the spudger under the daughterboard piece and lift it gently to remove it.
  15. Motorola Edge Plus 2022 I/O Board, I/O Board: step 15, image 1 of 1
    • Insert the flat end of a spudger under the I/O board and lift to remove it.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 39
All Time: 253
