Motorola Edge Plus 2022 Display Assembly Replacement
    1. Motorola Edge Plus 2022 Display Assembly Replacement, Battery: step 1, image 1 of 1
      • Press and hold the power button for 7 seconds.
      • You will know the phone is fully powered off when the Motorola logo appears on the screen.
      Ask FixBot
    2. Motorola Edge Plus 2022 Display Assembly Replacement: step 2, image 1 of 1
      • Insert a paperclip or SIM card ejector into the small hole located at the bottom of phone.
      • Gently push to release and remove the SIM card.
      Ask FixBot
    3. Motorola Edge Plus 2022 Display Assembly Replacement: step 3, image 1 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 3, image 2 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 3, image 3 of 3
      • Use an iOpener, heat gun, or hairdryer to gently heat the perimeter of the phone.
      • Insert and slide the iFixit opening pick around heated edges to sever the adhesive securing the rear cover.
      Ask FixBot
    4. Motorola Edge Plus 2022 Display Assembly Replacement: step 4, image 1 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 4, image 2 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 4, image 3 of 3
      • Gently remove the back cover using the suction handle or your bare hands.
      Ask FixBot
    5. Motorola Edge Plus 2022 Display Assembly Replacement: step 5, image 1 of 2 Motorola Edge Plus 2022 Display Assembly Replacement: step 5, image 2 of 2
      • While applying light pressure, remove the camera bezel cover by sliding the jimmy along the edges.
      Ask FixBot
    6. Motorola Edge Plus 2022 Display Assembly Replacement: step 6, image 1 of 2 Motorola Edge Plus 2022 Display Assembly Replacement: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the eleven 1.5 mm black screws.
      • In case a screw gets lost, the exact specifications for all screws in this guide are OEM MOTOROLA EDGE+ PLUS 5G UW.
      Ask FixBot
    7. Motorola Edge Plus 2022 Display Assembly Replacement: step 7, image 1 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 7, image 2 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 7, image 3 of 3
      • Remove the logic board by lifting gently with the flat end of the spudger.
      Ask FixBot
    8. Motorola Edge Plus 2022 Display Assembly Replacement: step 8, image 1 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 8, image 2 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 8, image 3 of 3
      • Use the flat end of a spudger to to pry up and disconnect the two press connectors on either side of the battery.
      • Located in the bottom left corner of the battery, remove the tape (black in the image) with a spudger.
      Ask FixBot
    9. Motorola Edge Plus 2022 Display Assembly Replacement: step 9, image 1 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 9, image 2 of 3 Motorola Edge Plus 2022 Display Assembly Replacement: step 9, image 3 of 3
      • Gently lift the battery up using the black spudger and remove.
      • Applying too much force when removing the battery may damage it. Take care not to bend, warp, or puncture the battery.
      • Apply a few drops of isopropyl alcohol if the battery is tightly adhered.
      Ask FixBot
    1. Motorola Edge Plus 2022 Display Assembly Replacement, Display Assembly: step 10, image 1 of 3 Motorola Edge Plus 2022 Display Assembly Replacement, Display Assembly: step 10, image 2 of 3 Motorola Edge Plus 2022 Display Assembly Replacement, Display Assembly: step 10, image 3 of 3
      • Use an iOpener or heat gun to heat the perimeter of the phone.
      • Only apply heat for 30-45 seconds. Using the iOpener for longer may damage the insides of the phone.
      • Insert an opening pick 3 mm into the seam between the display and chassis.
      • Slide the opening pick around the heated edges to sever the adhesive securing the display.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 107
All Time: 559
