Motorola Edge Plus 2022 Battery Replacement
    1. Motorola Edge Plus 2022 Battery Replacement, Battery: step 1, image 1 of 1
      • Press and hold the power button for 7 seconds.
      • You will know the phone is fully powered off when the Motorola logo appears on the screen.
      Ask FixBot
    2. Motorola Edge Plus 2022 Battery Replacement: step 2, image 1 of 1
      • Insert a paperclip or SIM card ejector into the small hole located at the bottom of phone.
      • Gently push to release and remove the SIM card.
      Ask FixBot
    3. Motorola Edge Plus 2022 Battery Replacement: step 3, image 1 of 3 Motorola Edge Plus 2022 Battery Replacement: step 3, image 2 of 3 Motorola Edge Plus 2022 Battery Replacement: step 3, image 3 of 3
      • Use an iOpener, heat gun, or hairdryer to gently heat the perimeter of the phone.
      • Insert and slide the iFixit opening pick around heated edges to sever the adhesive securing the rear cover.
      Ask FixBot
    4. Motorola Edge Plus 2022 Battery Replacement: step 4, image 1 of 3 Motorola Edge Plus 2022 Battery Replacement: step 4, image 2 of 3 Motorola Edge Plus 2022 Battery Replacement: step 4, image 3 of 3
      • Gently remove the back cover using the suction handle or your bare hands.
      Ask FixBot
    5. Motorola Edge Plus 2022 Battery Replacement: step 5, image 1 of 2 Motorola Edge Plus 2022 Battery Replacement: step 5, image 2 of 2
      • While applying light pressure, remove the camera bezel cover by sliding the jimmy along the edges.
      Ask FixBot
    6. Motorola Edge Plus 2022 Battery Replacement: step 6, image 1 of 2 Motorola Edge Plus 2022 Battery Replacement: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the eleven 1.5 mm black screws.
      • In case a screw gets lost, the exact specifications for all screws in this guide are OEM MOTOROLA EDGE+ PLUS 5G UW.
      Ask FixBot
    7. Motorola Edge Plus 2022 Battery Replacement: step 7, image 1 of 3 Motorola Edge Plus 2022 Battery Replacement: step 7, image 2 of 3 Motorola Edge Plus 2022 Battery Replacement: step 7, image 3 of 3
      • Remove the logic board by lifting gently with the flat end of the spudger.
      Ask FixBot
    8. Motorola Edge Plus 2022 Battery Replacement: step 8, image 1 of 3 Motorola Edge Plus 2022 Battery Replacement: step 8, image 2 of 3 Motorola Edge Plus 2022 Battery Replacement: step 8, image 3 of 3
      • Use the flat end of a spudger to to pry up and disconnect the two press connectors on either side of the battery.
      • Located in the bottom left corner of the battery, remove the tape (black in the image) with a spudger.
      Ask FixBot
    9. Motorola Edge Plus 2022 Battery Replacement: step 9, image 1 of 3 Motorola Edge Plus 2022 Battery Replacement: step 9, image 2 of 3 Motorola Edge Plus 2022 Battery Replacement: step 9, image 3 of 3
      • Gently lift the battery up using the black spudger and remove.
      • Applying too much force when removing the battery may damage it. Take care not to bend, warp, or puncture the battery.
      • Apply a few drops of isopropyl alcohol if the battery is tightly adhered.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 40
Past 30 Days: 246
All Time: 1,203
