Up to 20% off select tools
Motorola Edge Motherboard Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
103
All Time:
2,287
Comments: 4
4 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the motherboard on a Motorola Edge.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
The cameras connected to the motherboard can be removed in any order.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    1. Motorola Edge Motherboard Replacement, Find the SIM tray: step 1, image 1 of 1
      • Find the SIM tray located at the top of the phone.
      Ask FixBot
    2. Motorola Edge Motherboard Replacement, Eject the SIM tray: step 2, image 1 of 2 Motorola Edge Motherboard Replacement, Eject the SIM tray: step 2, image 2 of 2
      • Insert a SIM eject tool or SIM eject bit into the small hole in the SIM card tray.
      • If the tool you're using doesn't fit, don't force it. Forcing a tool may cause it to get stuck or break inside the ejection port.
      • Press to eject the tray.
      Ask FixBot
    3. Motorola Edge Motherboard Replacement, Remove the SIM card tray assembly: step 3, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the SIM card tray assembly: step 3, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the SIM card tray assembly: step 3, image 3 of 3
      • Remove the SIM card tray from the phone.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Heat the bottom edge: step 4, image 1 of 1
      • Completely power off your phone before you begin.
      • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Motorola Edge Motherboard Replacement, Separate the bottom adhesive: step 5, image 1 of 3 Motorola Edge Motherboard Replacement, Separate the bottom adhesive: step 5, image 2 of 3 Motorola Edge Motherboard Replacement, Separate the bottom adhesive: step 5, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Motorola Edge Motherboard Replacement, Slice the bottom adhesive: step 6, image 1 of 3 Motorola Edge Motherboard Replacement, Slice the bottom adhesive: step 6, image 2 of 3 Motorola Edge Motherboard Replacement, Slice the bottom adhesive: step 6, image 3 of 3
      • Slide the pick back and forth along the bottom edge to slice through the adhesive.
      • Leave the pick in to prevent the adhesive from resealing.
      Ask FixBot
    4. Motorola Edge Motherboard Replacement, Heat the right edge: step 7, image 1 of 1
      • Apply a heated iOpener to the back cover's right edge for two minutes.
      Ask FixBot
    5. Motorola Edge Motherboard Replacement, Separate the corner adhesive: step 8, image 1 of 3 Motorola Edge Motherboard Replacement, Separate the corner adhesive: step 8, image 2 of 3 Motorola Edge Motherboard Replacement, Separate the corner adhesive: step 8, image 3 of 3
      • Rotate the opening pick around the bottom-right corner of the phone.
      Ask FixBot
    6. Motorola Edge Motherboard Replacement, Separate the right adhesive: step 9, image 1 of 3 Motorola Edge Motherboard Replacement, Separate the right adhesive: step 9, image 2 of 3 Motorola Edge Motherboard Replacement, Separate the right adhesive: step 9, image 3 of 3
      • Insert a new opening pick into the gap you just created.
      • Slide the pick along the right edge of the phone to separate the adhesive.
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      Ask FixBot
    7. Motorola Edge Motherboard Replacement, Remove the back cover: step 10, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the back cover: step 10, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the back cover: step 10, image 3 of 3
      • Remove the back cover, taking care not to damage the components inside the phone.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Remove the motherboard's screws: step 11, image 1 of 1
      • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. Motorola Edge Motherboard Replacement, Remove the motherboard cover: step 12, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the motherboard cover: step 12, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the motherboard cover: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
      • The motherboard cover also contains the phone's flash.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Disconnect the interconnect cable from the motherboard: step 13, image 1 of 2 Motorola Edge Motherboard Replacement, Disconnect the interconnect cable from the motherboard: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Disconnect the battery cable's press connector: step 14, image 1 of 2 Motorola Edge Motherboard Replacement, Disconnect the battery cable's press connector: step 14, image 2 of 2
      • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Disconnect the screen ribbon cable's press connector: step 15, image 1 of 2 Motorola Edge Motherboard Replacement, Disconnect the screen ribbon cable's press connector: step 15, image 2 of 2
      • Use a spudger to pry up and disconnect the screen ribbon cable's press connector from the motherboard.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Remove the copper tape: step 16, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the copper tape: step 16, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the copper tape: step 16, image 3 of 3
      Buy
      • Use a pair of blunt tweezers to peel up and remove the copper tape covering the front camera ribbon cable.
      Ask FixBot
    2. Motorola Edge Motherboard Replacement, Remove the front camera cable's press connector: step 17, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the front camera cable's press connector: step 17, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the front camera cable's press connector: step 17, image 3 of 3
      • Use a spudger to pry up the front camera cable's press connector and disconnect it from the motherboard.
      • Remove the front camera.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Remove the wide angle camera's press connector: step 18, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the wide angle camera's press connector: step 18, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the wide angle camera's press connector: step 18, image 3 of 3
      • Use a spudger to pry up the wide angle camera cable's press connector and disconnect it from the motherboard.
      • Remove the wide angle camera.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Remove the main camera cable's press connector: step 19, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the main camera cable's press connector: step 19, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the main camera cable's press connector: step 19, image 3 of 3
      • Use a spudger to pry up the main camera cable's press connector and disconnect it from the motherboard.
      • Remove the main camera.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Remove the telephoto camera's press connector: step 20, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the telephoto camera's press connector: step 20, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the telephoto camera's press connector: step 20, image 3 of 3
      • Use a spudger to pry up and disconnect the telephoto camera cable's press connector from the motherboard.
      • Remove the telephoto camera.
      Ask FixBot
    1. Motorola Edge Motherboard Replacement, Disconnect the black coaxial cable: step 21, image 1 of 2 Motorola Edge Motherboard Replacement, Disconnect the black coaxial cable: step 21, image 2 of 2
      • Use a spudger to pry up the black coaxial cable and detach it from the motherboard.
      Ask FixBot
    2. Motorola Edge Motherboard Replacement, Disconnect the white coaxial cable: step 22, image 1 of 2 Motorola Edge Motherboard Replacement, Disconnect the white coaxial cable: step 22, image 2 of 2
      • Use a spudger to pry up the white coaxial cable and detach it from the motherboard.
      Ask FixBot
    3. Motorola Edge Motherboard Replacement, Remove the motherboard: step 23, image 1 of 3 Motorola Edge Motherboard Replacement, Remove the motherboard: step 23, image 2 of 3 Motorola Edge Motherboard Replacement, Remove the motherboard: step 23, image 3 of 3
      • Use a spudger to pry up and remove the motherboard.
      • Make sure no cables get trapped under the motherboard during reassembly.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2 other people completed this guide.
Author
with
Jennifer Berg
2,896 Reputation
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 103
All Time: 2,287
