Motorola Edge Motherboard Cover Replacement
    1. Motorola Edge Motherboard Cover Replacement, Heat the bottom edge: step 1, image 1 of 1
      • Completely power off your phone before you begin.
      • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: step 2, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: step 2, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: step 3, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: step 3, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: step 3, image 3 of 3
      • Slide the pick back and forth along the bottom edge to slice through the adhesive.
      • Leave the pick in to prevent the adhesive from resealing.
      Ask FixBot
    4. Motorola Edge Motherboard Cover Replacement, Heat the right edge: step 4, image 1 of 1
      • Apply a heated iOpener to the back cover's right edge for two minutes.
      Ask FixBot
    5. Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: step 5, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: step 5, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: step 5, image 3 of 3
      • Rotate the opening pick around the bottom-right corner of the phone.
      Ask FixBot
    6. Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: step 6, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: step 6, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: step 6, image 3 of 3
      • Insert a new opening pick into the gap you just created.
      • Slide the pick along the right edge of the phone to separate the adhesive.
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      Ask FixBot
    7. Motorola Edge Motherboard Cover Replacement, Remove the back cover: step 7, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Remove the back cover: step 7, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover, taking care not to damage the components inside the phone.
      Ask FixBot
    1. Motorola Edge Motherboard Cover Replacement, Remove the motherboard's screws: step 8, image 1 of 1
      • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: step 9, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: step 9, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
      • The motherboard cover also contains the phone's flash.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Jennifer Berg
2,893 Reputation
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 65
All Time: 515
