Motorola Edge (2022) Loudspeaker Replacement
    1. Motorola Edge (2022) Loudspeaker Replacement, Remove the SIM card tray: step 1, image 1 of 3 Motorola Edge (2022) Loudspeaker Replacement, Remove the SIM card tray: step 1, image 2 of 3 Motorola Edge (2022) Loudspeaker Replacement, Remove the SIM card tray: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the bottom edge of the phone.
      • Press the SIM eject tool into the sim card tray hole to eject the SIM card tray.
      • Use your fingers or tweezers to remove the SIM card tray.
      Ask FixBot
    1. Motorola Edge (2022) Loudspeaker Replacement, Heat the right edge: step 2, image 1 of 1
      • Completely power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's right edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Motorola Edge (2022) Loudspeaker Replacement, Separate the right adhesive: step 3, image 1 of 3 Motorola Edge (2022) Loudspeaker Replacement, Separate the right adhesive: step 3, image 2 of 3 Motorola Edge (2022) Loudspeaker Replacement, Separate the right adhesive: step 3, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
      • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Motorola Edge (2022) Loudspeaker Replacement, Slice the right adhesive: step 4, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Slice the right adhesive: step 4, image 2 of 2
      • Slide the pick along the right edge to slice the adhesive.
      • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
      Ask FixBot
    4. Motorola Edge (2022) Loudspeaker Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Apply a heated iOpener to the back cover's bottom edge for two minutes.
      Ask FixBot
    5. Motorola Edge (2022) Loudspeaker Replacement, Slice the bottom right corner adhesive: step 6, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Slice the bottom right corner adhesive: step 6, image 2 of 2
      • Rotate the pick around the bottom right corner to slice the adhesive.
      Ask FixBot
    6. Motorola Edge (2022) Loudspeaker Replacement: step 7, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 7, image 2 of 2
      • Slide the pick along the bottom edge to slice the adhesive.
      • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
      Ask FixBot
    7. Motorola Edge (2022) Loudspeaker Replacement: step 8, image 1 of 1
      • Apply a heated iOpener to the back cover's left edge for two minutes.
      Ask FixBot
    8. Motorola Edge (2022) Loudspeaker Replacement: step 9, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 9, image 2 of 2
      • Rotate the pick around the bottom left corner to slice the adhesive.
      Ask FixBot
    9. Motorola Edge (2022) Loudspeaker Replacement: step 10, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 10, image 2 of 2
      • Slide the pick along the edge to slice the adhesive.
      • Leave the pick in the top left edge to prevent the adhesive from resealing.
      Ask FixBot
    10. Motorola Edge (2022) Loudspeaker Replacement: step 11, image 1 of 1
      • Apply a heated iOpener to the back cover's top edge for two minutes.
      Ask FixBot
    11. Motorola Edge (2022) Loudspeaker Replacement: step 12, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 12, image 2 of 2
      • Rotate the pick around the top left corner to slice the adhesive.
      Ask FixBot
    12. Motorola Edge (2022) Loudspeaker Replacement: step 13, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 13, image 2 of 2
      • Slide the pick along the top edge to slice the adhesive.
      Ask FixBot
    13. Motorola Edge (2022) Loudspeaker Replacement, Remove the back cover: step 14, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Remove the back cover: step 14, image 2 of 2
      • Lift the back cover from the phone and remove it.
      • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
      Ask FixBot
    1. Motorola Edge (2022) Loudspeaker Replacement, Separate the camera bezel adhesive: step 15, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Separate the camera bezel adhesive: step 15, image 2 of 2
      • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
      • Slide the pick back and forth along the edge to slice the adhesive.
      Ask FixBot
    2. Motorola Edge (2022) Loudspeaker Replacement: step 16, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 16, image 2 of 2
      • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
      Ask FixBot
    3. Motorola Edge (2022) Loudspeaker Replacement, Remove the camera bezel: step 17, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Remove the camera bezel: step 17, image 2 of 2
      • Lift the camera bezel from the phone and remove it.
      • During reassembly:
      • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
      • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
      • Follow this guide to replace the back cover and camera bezel adhesive.
      Ask FixBot
    4. Motorola Edge (2022) Loudspeaker Replacement, Detach the left wireless charging coil tape: step 18, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Detach the left wireless charging coil tape: step 18, image 2 of 2
      • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
      • Slowly lift the spudger up until the tape detaches from the speaker.
      Ask FixBot
    5. Motorola Edge (2022) Loudspeaker Replacement, Detach the right wireless charging coil tape: step 19, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Detach the right wireless charging coil tape: step 19, image 2 of 2
      • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
      • Slowly lift the spudger up until the tape detaches.
      Ask FixBot
    6. Motorola Edge (2022) Loudspeaker Replacement: step 20, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 20, image 2 of 2
      • Use a Phillips screwdriver to remove the ten 4 mm screws securing the motherboard cover.
      Ask FixBot
    7. Motorola Edge (2022) Loudspeaker Replacement: step 21, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 21, image 2 of 2
      • Adhesive secures the motherboard cover to the motherboard itself.
      • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
      Ask FixBot
    8. Motorola Edge (2022) Loudspeaker Replacement: step 22, image 1 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 22, image 2 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 22, image 3 of 3
      • Insert an opening tool between the motherboard cover and the midframe.
      • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
      • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
      Ask FixBot
    9. Motorola Edge (2022) Loudspeaker Replacement, Remove the motherboard cover: step 23, image 1 of 3 Motorola Edge (2022) Loudspeaker Replacement, Remove the motherboard cover: step 23, image 2 of 3 Motorola Edge (2022) Loudspeaker Replacement, Remove the motherboard cover: step 23, image 3 of 3
      • Slowly pull the motherboard cover up and away from the phone and remove it.
      Ask FixBot
    1. Motorola Edge (2022) Loudspeaker Replacement, Move the graphite film: step 24, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Move the graphite film: step 24, image 2 of 2
      • Use your fingers to move the graphite film that covers the battery out of the way.
      Ask FixBot
    2. Motorola Edge (2022) Loudspeaker Replacement, Disconnect the battery: step 25, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Disconnect the battery: step 25, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    1. Motorola Edge (2022) Loudspeaker Replacement, Unfasten the daughterboard cover: step 26, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Unfasten the daughterboard cover: step 26, image 2 of 2
      • Use a Phillips screwdriver to remove the five screws securing the daughterboard cover:
      • Four 4.1 mm screws
      • One 3 mm screw
      Ask FixBot
    2. Motorola Edge (2022) Loudspeaker Replacement, Release the daughterboard cover clips: step 27, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Release the daughterboard cover clips: step 27, image 2 of 2
      • Insert a spudger under the daughterboard cover on the bottom right corner of the phone.
      • Pry up with the spudger to release the clips securing the cover.
      Ask FixBot
    3. Motorola Edge (2022) Loudspeaker Replacement, Remove the daughterboard cover: step 28, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Remove the daughterboard cover: step 28, image 2 of 2
      Buy
      • Use your fingers or tweezers to remove daughterboard cover.
      Ask FixBot
    4. Motorola Edge (2022) Loudspeaker Replacement, Disconnect the interconnect cable: step 29, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Disconnect the interconnect cable: step 29, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
      Ask FixBot
    5. Motorola Edge (2022) Loudspeaker Replacement: step 30, image 1 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 30, image 2 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 30, image 3 of 3
      • Use your fingers or tweezers to peel back and remove the tape on the fingerprint sensor cover.
      • Set the tape aside for reassembly.
      Ask FixBot
    6. Motorola Edge (2022) Loudspeaker Replacement, Unfasten the daughterboard: step 31, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Unfasten the daughterboard: step 31, image 2 of 2
      • Use a Phillips screwdriver to remove the two 3 mm screws:
      • One screw securing the fingerprint sensor cover.
      • One screw securing the daughterboard.
      Ask FixBot
    7. Motorola Edge (2022) Loudspeaker Replacement: step 32, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 32, image 2 of 2
      • Use your fingers or tweezers to remove the fingerprint sensor cover.
      Ask FixBot
    8. Motorola Edge (2022) Loudspeaker Replacement: step 33, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 33, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the fingerprint sensor's press connector.
      Ask FixBot
    9. Motorola Edge (2022) Loudspeaker Replacement: step 34, image 1 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 34, image 2 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 34, image 3 of 3
      • Use the pointed end of a spudger to pry up and disconnect the black antenna's coaxial connector.
      • Pry under the rounded edge of the coaxial connector, not the straight edge. If you pry under the straight edge, you may rip the socket off the daughterboard.
      • Use the spudger to push the antenna up and away from the phone until the cable is freed from the clip securing it to the daughterboard.
      • During reassembly, make sure the cable's metal band connects to the grounding clip in the daughterboard.
      • To re-attach coaxial connectors like this one, hold the connectors in place and gently press them straight down with your finger or the pointed end of a spudger.
      Ask FixBot
    10. Motorola Edge (2022) Loudspeaker Replacement: step 35, image 1 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 35, image 2 of 3 Motorola Edge (2022) Loudspeaker Replacement: step 35, image 3 of 3
      • Repeat the previous step for the white antenna cable.
      • During reassembly, make sure to put the cable back in its clip on the daughterboard.
      Ask FixBot
    11. Motorola Edge (2022) Loudspeaker Replacement: step 36, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement: step 36, image 2 of 2
      • Before you perform this step, be sure you’ve ejected the SIM tray.
      • Insert the pointed end of a spudger in the gap between the daughterboard and frame near the right edge of the phone.
      • Gently pry up to release the clips securing the daughterboard.
      Ask FixBot
    12. Motorola Edge (2022) Loudspeaker Replacement, Remove the daughterboard: step 37, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Remove the daughterboard: step 37, image 2 of 2
      • Use your fingers or tweezers to lift the daughterboard out of its recess and remove it.
      • During reassembly, make sure all cables that connect to the daughterboard (interconnect, fingerprint sensor, and antennas) are out of they way so they don't get stuck under the daughterboard when it's reinserted.
      Ask FixBot
    1. Motorola Edge (2022) Loudspeaker Replacement, Unfasten the loudspeaker: step 38, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Unfasten the loudspeaker: step 38, image 2 of 2
      • Use a Phillips screwdriver to remove the 4.1 mm screw securing the loudspeaker.
      Ask FixBot
    2. Motorola Edge (2022) Loudspeaker Replacement, Apply isopropyl alcohol: step 39, image 1 of 1
      • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the loudspeaker's contact pad to loosen the adhesive securing it.
      Ask FixBot
    3. Motorola Edge (2022) Loudspeaker Replacement, Remove the loudspeaker: step 40, image 1 of 2 Motorola Edge (2022) Loudspeaker Replacement, Remove the loudspeaker: step 40, image 2 of 2
      Buy
      • Use your fingers or tweezers to remove the loudspeaker.
      • The loudspeaker's flex cable is very fragile. Work slowly to prevent tearing the cable.
      • If you have a new adhesive piece for the cable, apply it now.
      • If there's any alcohol remaining, use a lint-free cloth to wipe it up or allow the alcohol to dry off before installing a new loudspeaker.
      Ask FixBot
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
Spencer Day
200,373 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,577 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 42
All Time: 802
