Motorola Edge (2022) Camera Bezel Replacement
    1. Motorola Edge (2022) Camera Bezel Replacement, Heat the right edge: step 1, image 1 of 1
      • Heat an iOpener and apply it to the back cover's right edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: step 2, image 1 of 2 Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: step 2, image 2 of 2
      • Insert an opening pick between the camera bezel and the back cover.
      Ask FixBot
    3. Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: step 3, image 1 of 2 Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: step 3, image 2 of 2
      • Slide the pick around the perimeter of the camera bezel to slice all the adhesive securing the bezel.
      • You may have to repeat this process multiple times to completely cut all of the adhesive.
      Ask FixBot
    4. Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: step 4, image 1 of 2 Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: step 4, image 2 of 2
      • Lift the camera bezel away from the phone and remove it.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Spencer Day
206,396 Reputation
1,268 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 85
All Time: 835
