Motorola Edge (2022) Back Cover Replacement
    1. Motorola Edge (2022) Back Cover Replacement, Heat the right edge: step 1, image 1 of 1
      • Completely power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's right edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: step 2, image 1 of 3 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: step 2, image 2 of 3 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
      • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: step 3, image 1 of 2 Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: step 3, image 2 of 2
      • Slide the pick along the right edge to slice the adhesive.
      • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
      Ask FixBot
    4. Motorola Edge (2022) Back Cover Replacement, Heat the bottom edge: step 4, image 1 of 1
      • Apply a heated iOpener to the back cover's bottom edge for two minutes.
      Ask FixBot
    5. Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: step 5, image 1 of 2 Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: step 5, image 2 of 2
      • Rotate the pick around the bottom right corner to slice the adhesive.
      Ask FixBot
    6. Motorola Edge (2022) Back Cover Replacement: step 6, image 1 of 2 Motorola Edge (2022) Back Cover Replacement: step 6, image 2 of 2
      • Slide the pick along the bottom edge to slice the adhesive.
      • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
      Ask FixBot
    7. Motorola Edge (2022) Back Cover Replacement: step 7, image 1 of 1
      • Apply a heated iOpener to the back cover's left edge for two minutes.
      Ask FixBot
    8. Motorola Edge (2022) Back Cover Replacement: step 8, image 1 of 2 Motorola Edge (2022) Back Cover Replacement: step 8, image 2 of 2
      • Rotate the pick around the bottom left corner to slice the adhesive.
      Ask FixBot
    9. Motorola Edge (2022) Back Cover Replacement: step 9, image 1 of 2 Motorola Edge (2022) Back Cover Replacement: step 9, image 2 of 2
      • Slide the pick along the edge to slice the adhesive.
      • Leave the pick in the top left edge to prevent the adhesive from resealing.
      Ask FixBot
    10. Motorola Edge (2022) Back Cover Replacement: step 10, image 1 of 1
      • Apply a heated iOpener to the back cover's top edge for two minutes.
      Ask FixBot
    11. Motorola Edge (2022) Back Cover Replacement: step 11, image 1 of 2 Motorola Edge (2022) Back Cover Replacement: step 11, image 2 of 2
      • Rotate the pick around the top left corner to slice the adhesive.
      Ask FixBot
    12. Motorola Edge (2022) Back Cover Replacement: step 12, image 1 of 2 Motorola Edge (2022) Back Cover Replacement: step 12, image 2 of 2
      • Slide the pick along the top edge to slice the adhesive.
      Ask FixBot
    13. Motorola Edge (2022) Back Cover Replacement, Remove the back cover: step 13, image 1 of 2 Motorola Edge (2022) Back Cover Replacement, Remove the back cover: step 13, image 2 of 2
      • Lift the back cover from the phone and remove it.
      • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Spencer Day
206,396 Reputation
1,268 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
1 Guide Comment
Where can I find the rear cover to replace it with? Mine is spiderwebbed.
bigrebone - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 105
All Time: 2,868
