Up to 20% off select tools
Motorola Edge (2021) Back Cover Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
84
All Time:
987
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Welcome to the Motorola Edge back cover removal guide. In this step-by-step walkthrough, we will assist you in safely removing the back cover of your Motorola Edge smartphone. Whether you need to replace a damaged cover or access internal components for repair, follow these instructions carefully to ensure a successful and safe removal process. Let's get started.
    1. Motorola Edge (2021) Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • To start you will need to soften the adhesive on the edges of the phone using two iOpeners.
      Ask FixBot
    2. Motorola Edge (2021) Back Cover Replacement: step 2, image 1 of 1
      • After the glue is soft, apply moderate force with the iFixit opening pick along the edge where the glue is located.
      Ask FixBot
    3. Motorola Edge (2021) Back Cover Replacement: step 3, image 1 of 1
      • After you have taken the glue off of the edges of the phone you can just easily pull the back cover off.
      Ask FixBot
By following this guide, you have successfully learned how to remove the back cover of your Motorola Edge smartphone. Remember to handle the device with care and follow all safety precautions.
Author
with
Kenai
229 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 84
All Time: 987
