Up to 20% off select tools
Motorola E815 interiorscreen replacement
Views: 2.9K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
84
All Time:
2,892
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
If the inside screen of your Motorola E815 is cracked or broken, you may need to replace it. In this guide you will:
  • Dissemble the phone to access the screen
    1. Motorola E815 interiorscreen replacement, Battery: step 1, image 1 of 1
      • Locate the back cover release slide.
      • Use your finger to slide it down.
      Ask FixBot
    2. Motorola E815 interiorscreen replacement: step 2, image 1 of 1
      • Remove the back cover by pulling it away from the phone.
      Ask FixBot
    3. Motorola E815 interiorscreen replacement: step 3, image 1 of 2 Motorola E815 interiorscreen replacement: step 3, image 2 of 2
      • Locate the battery removal slot.
      • Use your finger to pull the battery out from the top.
      • Remove the battery.
      Ask FixBot
    1. Motorola E815 interiorscreen replacement, Disassembling Motorola E815 Antenna: step 4, image 1 of 1
      • Locate the antenna port on the top of the phone.
      Ask FixBot
    2. Motorola E815 interiorscreen replacement: step 5, image 1 of 2 Motorola E815 interiorscreen replacement: step 5, image 2 of 2
      • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
      • Pull the apparatus up and out of the phone.
      Ask FixBot
    1. Motorola E815 interiorscreen replacement, Front Screen: step 6, image 1 of 3 Motorola E815 interiorscreen replacement, Front Screen: step 6, image 2 of 3 Motorola E815 interiorscreen replacement, Front Screen: step 6, image 3 of 3
      • Locate the two screws on the backside of the phone.
      • Unscrew the two screws using your T6 screwdriver.
      Ask FixBot
    2. Motorola E815 interiorscreen replacement: step 7, image 1 of 3 Motorola E815 interiorscreen replacement: step 7, image 2 of 3 Motorola E815 interiorscreen replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Grasp the top of the phone near the speaker.
      • Gently pull the top section of the phone upwards until you feel some resistance.
      • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
      • Using tweezers, gently pry the connector from the circuit board.
      • Detach the top section of the phone from the keypad section.
      Ask FixBot
    3. Motorola E815 interiorscreen replacement: step 8, image 1 of 2 Motorola E815 interiorscreen replacement: step 8, image 2 of 2
      • Carefully insert the blue pry tool into the notch between the two halves of the top section of the phone.
      • Gently pry the two halves apart.
      Ask FixBot
    4. Motorola E815 interiorscreen replacement: step 9, image 1 of 1
      • Rotate the top section of the phone around so that you are looking at the outer screen.
      • Disconnect the cover from the outer screen side of the phone.
      Ask FixBot
    5. Motorola E815 interiorscreen replacement: step 10, image 1 of 3 Motorola E815 interiorscreen replacement: step 10, image 2 of 3 Motorola E815 interiorscreen replacement: step 10, image 3 of 3
      • Rotate the top section of the phone around so you are looking at the large screen.
      • Using your fingers, lift the protector off of the screen.
      Ask FixBot
    6. Motorola E815 interiorscreen replacement: step 11, image 1 of 1
      • Using the blue pry tool, gently remove the screen cover.
      • Since it is glued into place, it may take some maneuvering to remove.
      Ask FixBot
    7. Motorola E815 interiorscreen replacement: step 12, image 1 of 3 Motorola E815 interiorscreen replacement: step 12, image 2 of 3 Motorola E815 interiorscreen replacement: step 12, image 3 of 3
      • Turn the phone so that you can see the side metal clasps.
      • Using the blue lifter tool, snap the metal clasps off of screen body.
      • Proceed to snap all four corners of the metal cover off of the screen body.
      Ask FixBot
    8. Motorola E815 interiorscreen replacement: step 13, image 1 of 2 Motorola E815 interiorscreen replacement: step 13, image 2 of 2
      • Using tweezers, gently detach the brown connecting strip from the back of the screen.
      • Separate the screen from the phone frame.
      • The front screen can now be accessed and replaced!
      Ask FixBot
    1. Motorola E815 interiorscreen replacement, Inside Screen: step 14, image 1 of 1
      • The inside screen can now be accessed for repair or replacement!
      Ask FixBot
Author
with
Zoie E
603 Reputation
5 Guides authored
Cal Poly, Team 14-8, Forte Winter 2011 Member of Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 84
All Time: 2,892
