Up to 20% off select tools
Motorola Droid X2 Screen Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
100
All Time:
1,854
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the screen as your may be scratched or cracked. This process does require tools, a heat gun in particular. Be careful to not heat your screen for too long as it can damage the electronics.
    1. Motorola Droid X2 Screen Replacement, Battery: step 1, image 1 of 3 Motorola Droid X2 Screen Replacement, Battery: step 1, image 2 of 3 Motorola Droid X2 Screen Replacement, Battery: step 1, image 3 of 3
      • Slide the plastic case off of the back of the phone, exposing the battery.
      Ask FixBot
    2. Motorola Droid X2 Screen Replacement: step 2, image 1 of 3 Motorola Droid X2 Screen Replacement: step 2, image 2 of 3 Motorola Droid X2 Screen Replacement: step 2, image 3 of 3
      • Pull up on the red battery release tab and pull the battery out of the phone.
      Ask FixBot
    1. Motorola Droid X2 Screen Replacement, Motherboard: step 3, image 1 of 2 Motorola Droid X2 Screen Replacement, Motherboard: step 3, image 2 of 2
      • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
      • Be careful to not strip any screws.
      Ask FixBot
    2. Motorola Droid X2 Screen Replacement: step 4, image 1 of 3 Motorola Droid X2 Screen Replacement: step 4, image 2 of 3 Motorola Droid X2 Screen Replacement: step 4, image 3 of 3
      • Using a prying tool, snap off the front casing on the top and bottom of the phone.
      • Be careful not to lose the small rubber piece that sits over the microphone.
      Ask FixBot
    3. Motorola Droid X2 Screen Replacement: step 5, image 1 of 2 Motorola Droid X2 Screen Replacement: step 5, image 2 of 2
      • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
      Ask FixBot
    4. Motorola Droid X2 Screen Replacement: step 6, image 1 of 3 Motorola Droid X2 Screen Replacement: step 6, image 2 of 3 Motorola Droid X2 Screen Replacement: step 6, image 3 of 3
      • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
      Ask FixBot
    5. Motorola Droid X2 Screen Replacement: step 7, image 1 of 3 Motorola Droid X2 Screen Replacement: step 7, image 2 of 3 Motorola Droid X2 Screen Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, remove the white wire at the top of the phone near the camera.
      Ask FixBot
    6. Motorola Droid X2 Screen Replacement: step 8, image 1 of 2 Motorola Droid X2 Screen Replacement: step 8, image 2 of 2
      • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
      Ask FixBot
    7. Motorola Droid X2 Screen Replacement: step 9, image 1 of 2 Motorola Droid X2 Screen Replacement: step 9, image 2 of 2
      • Using tweezers, removed the white electrical tape on the motherboard.
      Ask FixBot
    8. Motorola Droid X2 Screen Replacement: step 10, image 1 of 2 Motorola Droid X2 Screen Replacement: step 10, image 2 of 2
      • Using the plastic opening tool, lift up to remove the connector.
      Ask FixBot
    9. Motorola Droid X2 Screen Replacement: step 11, image 1 of 2 Motorola Droid X2 Screen Replacement: step 11, image 2 of 2
      • Using a pry tool, lift the jawbone connector.
      Ask FixBot
    10. Motorola Droid X2 Screen Replacement: step 12, image 1 of 2 Motorola Droid X2 Screen Replacement: step 12, image 2 of 2
      • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
      Ask FixBot
    11. Motorola Droid X2 Screen Replacement: step 13, image 1 of 3 Motorola Droid X2 Screen Replacement: step 13, image 2 of 3 Motorola Droid X2 Screen Replacement: step 13, image 3 of 3
      • Use a spudger to disconnect the cable connector.
      Ask FixBot
    12. Motorola Droid X2 Screen Replacement: step 14, image 1 of 3 Motorola Droid X2 Screen Replacement: step 14, image 2 of 3 Motorola Droid X2 Screen Replacement: step 14, image 3 of 3
      • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
      Ask FixBot
    1. Motorola Droid X2 Screen Replacement, Screen: step 15, image 1 of 2 Motorola Droid X2 Screen Replacement, Screen: step 15, image 2 of 2
      • Remove the 4 screws using a T-3 torques.. These screws are 2.40 mm in length.
      • Be careful to not strip the screws.
      Ask FixBot
    2. Motorola Droid X2 Screen Replacement: step 16, image 1 of 3 Motorola Droid X2 Screen Replacement: step 16, image 2 of 3 Motorola Droid X2 Screen Replacement: step 16, image 3 of 3
      Buy
      • Using tweezers, remove the white tape to reveal the connector
      Ask FixBot
    3. Motorola Droid X2 Screen Replacement: step 17, image 1 of 1
      • Using the plastic opening tool, lift the jawbone connector.
      Ask FixBot
    4. Motorola Droid X2 Screen Replacement: step 18, image 1 of 2 Motorola Droid X2 Screen Replacement: step 18, image 2 of 2
      • Using tweezers, remove cable from the connector
      Ask FixBot
    5. Motorola Droid X2 Screen Replacement: step 19, image 1 of 3 Motorola Droid X2 Screen Replacement: step 19, image 2 of 3 Motorola Droid X2 Screen Replacement: step 19, image 3 of 3
      • Using a plastic opening tool, lift the connector from the device
      Ask FixBot
    6. Motorola Droid X2 Screen Replacement: step 20, image 1 of 3 Motorola Droid X2 Screen Replacement: step 20, image 2 of 3 Motorola Droid X2 Screen Replacement: step 20, image 3 of 3
      • Lift the ribbon from the device
      • This does require some effort to remove.
      Ask FixBot
    7. Motorola Droid X2 Screen Replacement: step 21, image 1 of 3 Motorola Droid X2 Screen Replacement: step 21, image 2 of 3 Motorola Droid X2 Screen Replacement: step 21, image 3 of 3
      • Lift the screen off of the device
      Ask FixBot
    8. Motorola Droid X2 Screen Replacement: step 22, image 1 of 2 Motorola Droid X2 Screen Replacement: step 22, image 2 of 2
      • Using a heat gun, gently heat the edges of the screen
      • Be careful as overheating can damage the electronics.
      • The screen will be hot after.
      Ask FixBot
    9. Motorola Droid X2 Screen Replacement: step 23, image 1 of 3 Motorola Droid X2 Screen Replacement: step 23, image 2 of 3 Motorola Droid X2 Screen Replacement: step 23, image 3 of 3
      • Lift the screen from the frame.
      Ask FixBot
Author
with
Aaron Mak
658 Reputation
4 Guides authored
UMass Dartmouth, Team 4-3, Miles Fall 2014 Member of UMass Dartmouth, Team 4-3, Miles Fall 2014
UMASSD-MILES-F14S4G3
3 Members
48 Guides authored
1 Guide Comment
I recently ran into an interesting situation with the Droid X2 at my repair shop. I know this is an older device, but this is still a very important piece of information: there are 2 different types of digitizers and 2 different types of LCD's, depending on the Droid X2's transceiver number. Type A digitizer has a smaller front row button connector, Type B is larger. Same with the LCD, there is a Type A small connector and a Type B larger connector. Under the battery on the barcode sticker, right below the "MB870" barcode is the transceiver number, starting with "SJUG" and ending in either 6250 (type A) or 6065 (type B). Anyone buying a replacement LCD or digitizer needs to know which one to get, or else the connectors won't fit.
Andrew F - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 100
All Time: 1,854
