Motorola Droid X2 Rear Facing Camera Replacement
    1. Motorola Droid X2 Rear Facing Camera Replacement, Battery: step 1, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement, Battery: step 1, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement, Battery: step 1, image 3 of 3
      • Slide the plastic case off of the back of the phone, exposing the battery.
      Ask FixBot
    2. Motorola Droid X2 Rear Facing Camera Replacement: step 2, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 2, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 2, image 3 of 3
      • Pull up on the red battery release tab and pull the battery out of the phone.
      Ask FixBot
    1. Motorola Droid X2 Rear Facing Camera Replacement, Motherboard: step 3, image 1 of 2 Motorola Droid X2 Rear Facing Camera Replacement, Motherboard: step 3, image 2 of 2
      • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
      • Be careful to not strip any screws.
      Ask FixBot
    2. Motorola Droid X2 Rear Facing Camera Replacement: step 4, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 4, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 4, image 3 of 3
      • Using a prying tool, snap off the front casing on the top and bottom of the phone.
      • Be careful not to lose the small rubber piece that sits over the microphone.
      Ask FixBot
    3. Motorola Droid X2 Rear Facing Camera Replacement: step 5, image 1 of 2 Motorola Droid X2 Rear Facing Camera Replacement: step 5, image 2 of 2
      • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
      Ask FixBot
    4. Motorola Droid X2 Rear Facing Camera Replacement: step 6, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 6, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 6, image 3 of 3
      • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
      Ask FixBot
    5. Motorola Droid X2 Rear Facing Camera Replacement: step 7, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 7, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, remove the white wire at the top of the phone near the camera.
      Ask FixBot
    6. Motorola Droid X2 Rear Facing Camera Replacement: step 8, image 1 of 2 Motorola Droid X2 Rear Facing Camera Replacement: step 8, image 2 of 2
      • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
      Ask FixBot
    7. Motorola Droid X2 Rear Facing Camera Replacement: step 9, image 1 of 2 Motorola Droid X2 Rear Facing Camera Replacement: step 9, image 2 of 2
      • Using tweezers, removed the white electrical tape on the motherboard.
      Ask FixBot
    8. Motorola Droid X2 Rear Facing Camera Replacement: step 10, image 1 of 2 Motorola Droid X2 Rear Facing Camera Replacement: step 10, image 2 of 2
      • Using the plastic opening tool, lift up to remove the connector.
      Ask FixBot
    9. Motorola Droid X2 Rear Facing Camera Replacement: step 11, image 1 of 2 Motorola Droid X2 Rear Facing Camera Replacement: step 11, image 2 of 2
      • Using a pry tool, lift the jawbone connector.
      Ask FixBot
    10. Motorola Droid X2 Rear Facing Camera Replacement: step 12, image 1 of 2 Motorola Droid X2 Rear Facing Camera Replacement: step 12, image 2 of 2
      • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
      Ask FixBot
    11. Motorola Droid X2 Rear Facing Camera Replacement: step 13, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 13, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 13, image 3 of 3
      • Use a spudger to disconnect the cable connector.
      Ask FixBot
    12. Motorola Droid X2 Rear Facing Camera Replacement: step 14, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 14, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement: step 14, image 3 of 3
      • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
      Ask FixBot
    1. Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: step 15, image 1 of 3 Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: step 15, image 2 of 3 Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: step 15, image 3 of 3
      Buy
      • There should be jawbone connector here. However it was broken on this particular device. Lift it up using a pry tool.
      • Using tweezers, remove cable from motherboard.
      Ask FixBot
Aaron Mak
658 Reputation
4 Guides authored
UMass Dartmouth, Team 4-3, Miles Fall 2014 Member of UMass Dartmouth, Team 4-3, Miles Fall 2014
UMASSD-MILES-F14S4G3
3 Members
48 Guides authored
1 Guide Comment
how do u get it back on when it dose not come back on
brianna
Brianna Dittbrenner - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 672
