Motorola Droid Turbo Vibrator Replacement
    1. Motorola Droid Turbo Vibrator Replacement, Rear Case: step 1, image 1 of 1
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      Ask FixBot
    2. Motorola Droid Turbo Vibrator Replacement: step 2, image 1 of 2 Motorola Droid Turbo Vibrator Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      Ask FixBot
    1. Motorola Droid Turbo Vibrator Replacement, Midframe: step 3, image 1 of 1
      • Remove the midframe bezel.
      Ask FixBot
    2. Motorola Droid Turbo Vibrator Replacement: step 4, image 1 of 1
      • Remove the four Torx T5 screws securing the midframe plate.
      Ask FixBot
    3. Motorola Droid Turbo Vibrator Replacement: step 5, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Motorola Droid Turbo Vibrator Replacement, Vibrator: step 6, image 1 of 2 Motorola Droid Turbo Vibrator Replacement, Vibrator: step 6, image 2 of 2
      • Use the pointed end of a spudger to gently pry the vibrator up and away from the midframe.
      Ask FixBot
Geoff Wacker
93,072 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 113
All Time: 1,676
