Motorola Droid Turbo Headphone Jack Replacement
    1. Motorola Droid Turbo Headphone Jack Replacement, Rear Case: step 1, image 1 of 1
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      Ask FixBot
    2. Motorola Droid Turbo Headphone Jack Replacement: step 2, image 1 of 2 Motorola Droid Turbo Headphone Jack Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      Ask FixBot
    1. Motorola Droid Turbo Headphone Jack Replacement, Midframe: step 3, image 1 of 1
      • Remove the midframe bezel.
      Ask FixBot
    2. Motorola Droid Turbo Headphone Jack Replacement: step 4, image 1 of 1
      • Remove the four Torx T5 screws securing the midframe plate.
      Ask FixBot
    3. Motorola Droid Turbo Headphone Jack Replacement: step 5, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Motorola Droid Turbo Headphone Jack Replacement, Headphone Jack: step 6, image 1 of 2 Motorola Droid Turbo Headphone Jack Replacement, Headphone Jack: step 6, image 2 of 2
      • Insert the pointed end of a spudger into the headphone jack, and gently pry the jack up and away from the midframe.
      Ask FixBot
3 other people completed this guide.
Geoff Wacker
92,942 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 3,729
