Motorola Droid Turbo Front Facing Camera Replacement
    1. Motorola Droid Turbo Front Facing Camera Replacement, Rear Case: step 1, image 1 of 1
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      Ask FixBot
    2. Motorola Droid Turbo Front Facing Camera Replacement: step 2, image 1 of 2 Motorola Droid Turbo Front Facing Camera Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      Ask FixBot
    1. Motorola Droid Turbo Front Facing Camera Replacement, Midframe: step 3, image 1 of 1
      • Remove the midframe bezel.
      Ask FixBot
    2. Motorola Droid Turbo Front Facing Camera Replacement: step 4, image 1 of 1
      • Remove the four Torx T5 screws securing the midframe plate.
      Ask FixBot
    3. Motorola Droid Turbo Front Facing Camera Replacement: step 5, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: step 6, image 1 of 2 Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: step 6, image 2 of 2
      • Use the pointed end of a spudger to flip up the black retaining flap of the front facing camera's ZIF connector.
      Ask FixBot
    2. Motorola Droid Turbo Front Facing Camera Replacement: step 7, image 1 of 2 Motorola Droid Turbo Front Facing Camera Replacement: step 7, image 2 of 2
      • Remove the front-facing camera.
      Ask FixBot
Luis Arangu
1,151 Reputation
3 Guides authored
USF Tampa, Team 15-5, Remmell Spring 2016 Member of USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 102
All Time: 2,265
